high mileage 12v upgrades?
Postby imfixinmopars » Thu May 10, 2007 5:15 am
i have a 92 12v,w/ 525000 miles,and been well taken care off.i would like to turn up the pump,and what ever else will help.i put a straight 3" exhaust on it also.is it safe to put more fuel/boost to this ol'girl?? it only had 12psi boost,and i screwed in the full power 2 turns and got 20-22 psi,and runs much better,but should i go farther?,meaning star/full load adj. i dont have a pyro yet,but i want your opinion on the mileage vs. boost,thanks and yes im a newbee.
93 excab stinker 2wd/5spd
03 duramax 4x4
mopars buy the dozen,lol
imfixinmopars
Postby meby » Thu May 10, 2007 10:25 am
I'd grind away at the fuel pin, that makes a huge difference on the off the line response of these trucks. Diffinately get a pyro.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby imfixinmopars » Thu May 10, 2007 5:16 pm
im looking for a pyro this weekend,at the local swap.im sure the pump is stock.i just hauled my 863 bobcat w/ my dozer trailer today,and the truck did ok,just need a little more power,as always.the load was about 13k lbs,and it did ok,but the truck rode harsh.i have airbags for it too,i will try.soon as i get a pyro,i will go internal on the pump.if you guys think its safe w/ the miles?????thanks
03 duramax 4x4
imfixinmopars
Postby Begle1 » Fri May 11, 2007 3:11 pm
I wouldn't worry about the miles, based on what I've read on the internet. Pumps seem to fail anywhere from 300,000 to 1,200,000 miles, tweaked or not.
Postby whereswaldo250 » Mon May 21, 2007 10:49 am
Thats a bunch of miles miles but then again mine only has 151k
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
