piston lift pump?
piston lift pump?
Postby tjsmokin » Fri Jan 29, 2010 5:49 pm
is the stock replacement piston lift pump from a 94/98 second gen the same psi as the low pressure lift pump? i ordered one from a parts house and am a little scared to put it on. think it might be to high or pressure and blow seals or something. anyone know exactly?[/img]
tjsmokin
Postby lectro_static » Fri Jan 29, 2010 5:53 pm
yes it is to high pressure, you can get a boost referenced pressure regulator and run it.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby Richie O » Fri Jan 29, 2010 5:59 pm
You can also get a dead head regulator as well and set it at 15 psi. It won't hurt the lift pump to be regulated.
