Super 40 off 01 on my 89
Postby doug1810 » Tue May 15, 2007 3:34 am
I have a hx 40 off 01 with waste gate would like to put on my 89 . I know i have to loosen the snap ring and spin the out let but what about the waste gate do i just use springs ?
doug1810
Postby Greenleaf » Tue May 15, 2007 9:02 am
I don't know enough about that turbo to know what you mean by the use of springs........
What do the springs do? Where are they?
I don't know that the turbo would be any different from all the other waste gated units. Bolt it on.
Greenleaf
tech specialist/mod
Postby doug1810 » Tue May 15, 2007 9:06 am
it has a waste gate but when i turn the outlet to work on the 89 non i/c the waste gate wont be able to stay bolted up . I think :? . could use some help it looks just like an hy 35 off an 01 i dont know how to keep the waste gate hooked up
doug1810
Postby PToombs » Tue May 15, 2007 4:52 pm
I put a 35 on mine, I had to pull the lineup pin on the compressor housing.I used my 16cm exhaust housing, no wastegate!
Postby KTA » Tue May 15, 2007 7:24 pm
A super 40 will bolt right on, but if that is an HY35 the wastegate is bolted to the compressor cover so you cant reorient it like a HX35 or an HX40.
Postby doug1810 » Wed May 16, 2007 8:02 am
thanks i thought it bolted the same as the hy 35
doug1810
Postby gman07 » Wed May 16, 2007 12:54 pm
You'd also have to make a custom exhaust for the Super 40; it should have a 4" outlet. You could make a bracket for the wastegate, but it's kind of a pain. You might be able to find an exhaust housing for it (16cm^2) with a wastegate actuator that is oriented differently to work on your truck.
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby doug1810 » Thu May 17, 2007 3:13 am
thanks i will keep an eye out i am going to play with it this weekend
doug1810
