Fuel pump linkage
Fuel pump linkage
Postby jeff77indy » Sat Feb 13, 2010 11:53 am
What's a good source for the male and female ball joints for the throttle linkage?
Thanks
Jeff
U.S. Navy Submarine Service Retired
1992 W350 C&C w/ 9' flatbed, NV5600, Skyjacker 2" lift, Borgeson , Isspro, draw straw, big line kit, piston lp, swiss cheesed air housing.
jeff77indy
Re: Fuel pump linkage
Postby bgilbert » Sat Feb 13, 2010 12:28 pm
Cummins Distributor. Both ends, nuts and the rod itself will supercede to the complete upgrade kit. Part number should be located in the Part Number Forum. On edit, the Cummins part number is 4089076. There's also a Mopar number for the same thing from your local Dodge dealer floating around on the net as well.
Bill Gilbert
bgilbert
Postby burnt_servo » Mon Feb 15, 2010 2:10 am
when i rebuilt did the linkage on my m37 , i used a local industrial bearing shop to get the small ball joints that i needed .
'93 w250 .... stock ...
burnt_servo
Postby jeff77indy » Tue Feb 23, 2010 10:43 am
What are the thread measurements needed for these? May have to find them else where.
I checked with my local Cummins parts house and they are out until March /April time frame. Also stated there won't be any in the pipe line until then also.
Jeff
jeff77indy
Postby SNOOT » Tue Feb 23, 2010 11:00 am
1993 W350
SNOOT
Postby ccoxva » Tue Feb 23, 2010 3:41 pm
SNOOT wrote:Image
Nice engine bay!!! :grin:
1991 N/I 250
1996 Dodge 3500 Ex. Cab Dually 19.5's
ccoxva
