1991 dodge intercooler
Postby diesel mechanic » Wed Feb 17, 2010 7:12 pm
ok i have a 1989 dodge cummins. i bought a 1991 rust free dodge for parts. im wondering what all i would have to change to make truck intercooled. as in radiator and so on? i only got a body from the 1991 so i dont have a intercooler yet either. hope someone can help with my quwstion
diesel mechanic
Re: 1991 dodge intercooler
Postby Remps » Wed Feb 17, 2010 7:45 pm
I think it would be pointless to swap rad supports just to have I/C mounts.Unless you're gonna switch to a crossflow I/C rad,then you'll need a top rad hose,thermostat housing,and trim the fan shroud,unless you switch to an I/C fan.Cheaper to make mounts for the I/C,and cut holes for the plumbing.Then you just need the I/C,intake horn,and the plumbing. I swapped everything but the fan cause I have (had) a complete parts truck.
