Fuel lines?
Fuel lines?
Postby jeff77indy » Tue Feb 23, 2010 10:57 am
Anyone running the larger fuels from the tank to the filter/lift pump and then to the IP?
I was thinking on something similar to the big line kit from Geno's/Vulcan with the AN fittings and such. Is this worth while?
I found where one member installed his own version of a draw straw would this be worth while on a basicly stock 12 valve?
I've done these to my 2001 Ram 2500 24 valve.
jeff77indy
Re: Fuel lines?
Postby BobS » Tue Feb 23, 2010 11:16 am
I increased my line size from the factory 5/16" size to a true 3/8" size starting right at the tank connector. I don't think I gained anything by doing it other than slightly increasing the flow to the lift pump. I kept the return line the same as it was at 5/16" For those of you who haven't had the line off, it turns out the line is actually 5/16" going in both directions as installed from the factory in 1991.5 trucks. The ends are flared out to 3/8" OD.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: Fuel lines?
Postby IowaCummins » Tue Feb 23, 2010 12:05 pm
i plan on doing a full 1/2" supply line to my lift pump this summer. i have a double filter setup as well then runa water seperator also. 2nd gen lift pump and a regulator. over kill at its best but its the way i want to do it.
IowaCummins
Re: Fuel lines?
Postby 1STGENFARMBOY » Tue Feb 23, 2010 12:17 pm
I want to do that same thing i already have one of the big filters on, i built it from stuff i found at a farm store a big 2 micron filter for a tank pump., but i have another one that came off a detroit with a pump,regulater,water seperator,return outlet,heater,and drain, sweet set up when i get it on, the bad part is the heater is 24v. i also want to go 2nd gen lp cause i can 0psi in an instant. :pale:
Re: Fuel lines?
Postby dieseldawg604 » Sun Apr 18, 2010 9:44 pm
IowaCummins wrote:i plan on doing a full 1/2" supply line to my lift pump this summer. i have a double filter setup as well then runa water seperator also. 2nd gen lift pump and a regulator. over kill at its best but its the way i want to do it.
i wouldnt call it over kill
you hplp stll chokes down to about 1/4 inch inside the pump
i doubt if it would be any different than the lplp
1990 w250 auto 1400stall tc, 100gph electric pump, dual filters, 1/2" lines to ip,
he351cw, 3"crossover, stainless waterjet airhorn, 4"dp to 5" dual miters
dieseldawg604
