ve pump keyway
ve pump keyway
Postby diesel mechanic » Wed Feb 24, 2010 5:34 pm
im wondering if any body knows where i can a a ve pump keyway i cant find one thanks
diesel mechanic
Re: ve pump keyway
Postby PToombs » Wed Feb 24, 2010 6:05 pm
Probably the best bet is the local fuel shop. I think I read somewhere that it's a metric woodruff key.
Re: ve pump keyway
Postby 1STGENFARMBOY » Thu Feb 25, 2010 5:39 pm
Diesel Mechanic you could measure it with a dial indicator if you can get close but to big you can tweek it with a file, (TAP) it in gently it'll be great.
