hard starting still
hard starting still
Postby randyswelding » Sun Mar 14, 2010 5:06 pm
i got a question that has me stumped,the truck will crank and crank and then start this is like after a couple of turns of the motor, its like it has air in the system some where but i cant find it. i bleed the sticks today and went to bass pro and h&h guns and at both places it didnt want to start.all the nuts,bolts,conections are tight new return line and the air dog fuel line.the truck currently has the 370 sticks,air dog 150,pump set mild(i was hittin 38psi now 34psi and didnt change the fuel screw :( ) so this has me confused!i checked everything i dont know how many times and it just doesnt want to start but it will.its just not fun movin around in the rig yard!any ideas i will try anything right now to get it back to startin on the first bump of the starter
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Re: hard starting still
Postby TWorline » Sun Mar 14, 2010 6:50 pm
Randy:
Only 2 things I can think of. Are you making oil by chance? The fuel could be going out through the front seal. Check the lock nut on the fuel screw. If it has rattled loose it could allow the fuel screw to back out and allow air in.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Remps » Sun Mar 14, 2010 7:23 pm
The IP could be getting tired. How many miles on it? I would try turning up the fuel screw to see if it makes any difference in starting.
Postby TWorline » Sun Mar 14, 2010 7:52 pm
Remps wrote:The IP could be getting tired. How many miles on it? I would try turning up the fuel screw to see if it makes any difference in starting.
I thought about that as well but didn't want to mention it. :bom:
Tim Worline
TWorline
Postby BobS » Mon Mar 15, 2010 4:58 am
Lift pump issue? How old, which one & did you test the pressure?
Fuel filter gasket & o-ring? Filter tight?
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby randyswelding » Mon Mar 15, 2010 6:05 pm
air dog 150 lp and 15psi on crankin and 17 runnin on the highway filters tight and as far as makin oil? i dont get it the oil smells oily let me go look though and around 15k miles on that pump since the rebuild that a fellow member on here had done philip knows the guys name i got the motor from
randyswelding
Postby randyswelding » Mon Mar 15, 2010 6:09 pm
wade fisher is who i got it from and the oil smells oily not fuelly
randyswelding
Postby randyswelding » Mon Mar 15, 2010 6:26 pm
tried the fuel screw nut alittle loose but still tight i did turn it up a little more :lol: if i lost the front seal wouldnt the pan be fillin up with fuel and i would be pumpin fuel into the pan?
randyswelding
Postby burnt_servo » Mon Mar 15, 2010 7:20 pm
have you played with the timing yet ?
is it possible your motor is getting tired ?
does using or not using your grid heater make any difference ?
'93 w250 .... stock ...
burnt_servo
Postby Remps » Mon Mar 15, 2010 9:24 pm
When you crack all the injector lines loose and crank it, does it spray fuel all over, or does it just blow bubbles? :yuck:
Postby jogl » Tue Mar 16, 2010 3:54 am
It takes a lot of fuel in your oil before you can smell it. We had over a gallon extra in a combine motor one time (Perkins 354, that holds about 2 1/2 gallons of oil) and could not smell diesel at all.
JP.
92 W250 and lots of others.
jogl
Postby randyswelding » Tue Mar 16, 2010 5:06 pm
motor is on a fresh rebuild like got put back in the begining of october of 09, and the oil level hasnt gone up since i had to put oil in it last week (leaky valley cover but not no more)its at the top line and hasnt moved up. timing is the 1/8" bump on the stock gear marks i havent tryed to crack all lines then crank yet but with it runnin and crack 1 by 1 its just air. im freakin lost cause i had to move 5 times today and spent more time crankin then movin :x
randyswelding
Postby oklahoma6speed » Tue Mar 16, 2010 5:21 pm
its the driver. lol.
the 6x16. i better come get them from ya. dont want them to waste setting in a box. getten dusty
oklahoma6speed
Postby randyswelding » Tue Mar 16, 2010 7:12 pm
so i loostened all sticks and had dad crank and crank i got the 1st 3 tightened and it fired then finished tightening the rest and seem to run smoother but when i turned it off the same stuff again.so i went to the air dog and the filter was only hand tight and not that tight at all and the water filter had a good amount of water so i tightened the filter and drained the water out so ill find out tomarrow how it is i still need to work on the welder (oil and plugs)tonight
randyswelding
Postby randyswelding » Tue Mar 16, 2010 7:14 pm
curtis you still dont get them once i figure this out they go back in :D
randyswelding
