by Collers9640 » Sat Mar 20, 2010 8:41 pm
I just installed an HX35 in my truck. It has a wastegate and I'm having a problem with a lack of boost. My H1C was performing better. Can I remove the wastegate and simple plug the hole in the compressor housing?. What is the best thing to do to get the most boost out of my turbo. Also the turbo is out of a 2000 Dodge if that helps.
