1993 Dodge cummins high pressure turbo oil line
Postby 93DodgeCummins » Thu Apr 01, 2010 8:33 pm
does any one know where i can get a turbo oil line for my 1993 dodge cummins? i tried lookin on the internet but i had no luck.
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: 1993 Dodge cummins high pressure turbo oil line
Postby SNOOT » Thu Apr 01, 2010 8:39 pm
Just a stock one?
I have both fittings and the line for a shipping fee..
1993 W350
SNOOT
Postby oldestof11 » Thu Apr 01, 2010 8:48 pm
O'Reilly can make you a new one if you have both ends.
Postby 93DodgeCummins » Thu Apr 01, 2010 9:04 pm
i still have the oil line and fittings
93DodgeCummins
Postby 93DodgeCummins » Fri Apr 02, 2010 4:53 pm
is there a part number from cummins for it?
93DodgeCummins
Postby jhedge » Sat Apr 03, 2010 8:38 pm
The Cummins number for a 93 should be 3912747. I could tell you for sure if I had your serial number. Any Cummins parts guy should be able to look it up by enginer serial number as well.
jhedge
