Picked up a p-pumped 5.9
Postby Falcon » Tue Apr 06, 2010 7:17 am
I got this 5.9 out of a 93 bus. It's p-pumped. The head and block is the same as my 93 5.9 correct? What is the p-pump worth? It also has a air compressor where the vaccume pump is located. I will be listing things for sale with photos.
Greg
Graham, Washington
"FIRST REAL TRUCK ENGINE...
LAST REAL TRUCK!!!
93 ex cab 4x4, Hybred 35/40,4" exaust all the way,pump turned alittle,DDP Stage III's, 366 spring,DDP fuel pin,AFE first gen air intake,pyro and boost gauges
Falcon
Re: Picked up a p-pumped 5.9
Postby jhedge » Tue Apr 06, 2010 9:54 pm
There were actually a handful of different block and head part numbers for the 5.9, but in most cases you would be hard pressed to tell the difference if you had two of them next to each other. If you have engine serial numbers for both engines I could tell you the difference pretty quickly.
It's probably not woth as much as the pump, but that compressor might be worth a few bucks too, particularly if it's a Holset.
jhedge
Postby SNOOT » Tue Apr 06, 2010 10:33 pm
That short block is mine!!!!! Tell me the price..
1993 W350
SNOOT
Postby Falcon » Wed Apr 07, 2010 7:58 am
Lance you need to come over and look at what I have........
Greg
Graham, Washington
LAST REAL TRUCK!!!
Falcon
