Piston Design
Piston Design
Postby Begle1 » Sat Jun 02, 2007 4:05 pm
Has anybody anywhere ever tried any other kind of piston than the bowl-shape?
What's the point of the bowl? Why does fuel burn better in the bowl than out in the open?
Postby dpuckett » Sun Jun 03, 2007 12:56 pm
The bowl of the piston provides a place for the fuel to burn, as the piston gets REALLY close to the head. If it werent for the bowl, it would never get a place to burn, and the piston would hit the injector tip. So, you make a bowl, make an injector tip in which the spray pattern matches the bowl deisgn, giving maximum air fuel mixture potential, and BOOM, you have a direct injected diesel engine.
As for other bowl deisgns, there are guys who are running extreme HP that have gone to the lower compression marine pistons.
Daniel
Postby Begle1 » Sun Jun 03, 2007 2:37 pm
So, if it wasn't for the bowl, the stream of fuel from the injector would end up splattering itself all over the top of the piston.
And the piston itself could hit the injector.
So I take it that the marine pistons are basically the same design? What sort of compression do they run?
Postby KTA » Mon Jun 04, 2007 6:02 am
Marine pistons are 15.3:1 and have a lot bigger bowl.
Postby Cowboy_Customs » Sat Jun 09, 2007 1:13 pm
Ok, I have to ask, what is the acctual benefit of running the low compression marine pistons? I understand for extreme HP u gotta lower compression. But what would happen if you put these on a street driven truck, with mild power, say 400, 450?
Im going to have my long block assembly to play with here (granted it survived the accident n didnt kill the block) so I want to "build it up" with some nice aftermarket pieces, pistons, cam......
Lost, but not forgotten. '93 Dodge D-350 regular cab 2x6, 5-speed, Phantom Pyro, LED guages, Polished valve covers, 366 spring, 4 inch Rip DP, to 6 inch stacks, lots 'o lights
http://community.webshots.com/user/Cowboy_Customs
Cowboy_Customs
Postby dpuckett » Tue Jun 12, 2007 9:08 pm
Go read what these guys have to say about building high performance Cummins N14s- www.dieselinjection.net . I'd assume the theorise could be adapted to the B-series. Basically, when one lowers compression, the airflow needs to be increased to offset the lower compression & cooler combustion. The increase in airflow to the cylinders, along with the reduced cylinder pressures during combustion, allow for some serious high HP potential.
Daniel
Postby Cowboy_Customs » Thu Jun 14, 2007 7:14 am
wow.
I have been to their site before looking for the box for my freightliner, but never read any of the articles before on the NTC!
Now I really want that 82 Frightliner stretch frame with the bag cam IV for sale down the road!! lol
Thats some great reading
Cowboy_Customs
air flow
Postby charger 69 » Fri Jun 15, 2007 2:05 pm
For increasing air flow in our trucks these reground cams must be just what the doctor ordered. Correct me if I am wrong but wouldn't a cam would be right up there with a larger turbo when it comes to air flow??
92 White D350 132K,mi. fuel screw in 3,5 turns automatic with a Hughes converter and 26K add on cooler.Aluminum wheels,second fuel tank,gooseneck hitch,air bags tach.and gages,
charger 69
Postby gman07 » Fri Jun 15, 2007 2:50 pm
Based on what I've read and the conclusions I've drawn, a cam and ported head would probably help a 1st gen out quite a bit. The cam is relatively inexpensive ($750 for a Helix 2 IIRC) but the work putting one in is quite a bit more than just swapping a turbo.
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby charger 69 » Sat Jun 16, 2007 7:31 am
gman07, you are right without a doubt on turbo replacement but i am just thinking of options as I intend to lay up my rig and do a major update-overhall-add on, in the next year or so I have the HP.and a drive line that can handle it. :)
charger 69
Postby KTA » Sat Jun 16, 2007 7:36 am
I made 627rwhp #2 only with a stock cam. I will be running one of my cams in Old yellow version 2.0.
Postby charger 69 » Sat Jun 16, 2007 5:01 pm
KTA, I kind of like the setup you have on your towing truck as I pull about the same weight. If I move into a state that is tough on emissions I don't want to deal with excessive smoke for state inspection unless its easy to turn it down, not saying a cam would help at all.
charger 69
Postby dpuckett » Tue Jun 19, 2007 5:32 pm
A cam would probably help the smoke reduction, as they allow more air into the cylinders.
