burning oil
burning oil
Postby silver91.5 » Fri Apr 16, 2010 4:09 pm
i got a 91.5 w250 runs great but burns oil bad i drove it 500 miles this week and it used 2.5-3 quarts of oil not leaking burning. truck runs perfect been getting 20-22mpg its bone stock just has the smoke screw turned in where do i start to find the problem? any help would be great as this is my first diesel and i dont know much about them
silver91.5
Re: burning oil
Postby oldestof11 » Fri Apr 16, 2010 5:06 pm
How bad is the blow-by? Any?
If not, I would think the blow-by tube is clogged, and the crank case pressure is blowing oil past the rings.
Any blue, burning oil smell?
Re: burning oil
Postby Richie O » Fri Apr 16, 2010 5:30 pm
Turbo seal gone maybe.
Re: burning oil
Postby peobryant » Tue Apr 20, 2010 9:20 pm
Richie O wrote:Turbo seal gone maybe.
That would cause bluish tinted smoke, correct?
Re: burning oil
Postby Greenleaf » Wed Apr 21, 2010 11:52 am
my 90 with 320+ thousand does not burn any oil of which I have noticed. You likley have something wrong other than wear and tear. I have not touched the valve stem seals either. No blow by to speak of.
Greenleaf
tech specialist/mod
