by Richie O » Mon Apr 19, 2010 8:24 pm
If your plans are to stay with a stock lift pump a 15 is fine. If you plan to upgrade to a better set up like a low pressure piston lift pump or another better unit I would go with a 30 psi. You will be in the upper limits of a 15psi gauge with a better pump. Do not get a hundred. With our set ups a 100 will read near 0 or be hard to read. I have a isspro 30 psi in mine. I have another on the shelf for my 89. ( to many projects )
