Vacuum Pump Oil Leak
Postby Power Wagon Guy » Sat Apr 24, 2010 5:09 pm
I got a leak where the vacuum pump meets the PS ...i'm assuming it need new seals....how difficult of a job is this?........
Power Wagon Guy
Re: Vacuum Pump Oil Leak
Postby Mark Nixon » Sat Apr 24, 2010 9:32 pm
If it's an Intercooled engine, it's PROBABLY the o-ring between the vacuum pump and the power steering pump.
They are fairly simple to fix, just undo the lower rear bracket on the power steering pump, unscrew the 2 nuts that hold the vacuum pump to the power steering pump, then they slide apart.
The 'O' ring is right there, but I don't recall if it's on the vacuum pump side, or the P/S side.
You SHOULDN'T have to disconnect any lines, but don't quote me on that.
A non-intercooled one is a real PITA to do, as it's all pressed together.
Postby Power Wagon Guy » Sun Apr 25, 2010 5:06 am
Thanks for that info, it is in a intercooled 93.....will check it out today.
Power Wagon Guy
