Stock lift pump blues
Postby tim curran » Tue Apr 27, 2010 1:37 pm
I have come to the conclusion that my stock fuel pump just aint cutting it. What is the best option to replace it. Should I ad an electric fuel pump to my stock mech. I know I could put an airdog pump on, but right now i don't want to spend 500 bucks on a pump.
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Re: Stock lift pump blues
Postby 1STGENFARMBOY » Tue Apr 27, 2010 1:56 pm
I just installed a holley black pump and a homemade filter and bypassed my factory pump and filter
and i can hold 12 psi at idle and 9 at WOT and thats pretty good with my mods, the stock pump was
holding 5 at idle and at the instant i punched the peddle it would drop to (0) psi, so i'm very happy
with my $145.00 pump. some members are using the knock off holley black and they have the same
results as i do but for 1/3 the cost, i think i saw some on e-bay for $45.00 plus S/H.
Postby PRINCETON_JAKE » Tue May 04, 2010 7:32 pm
I like the piston style mechanical lift pump, i personally dont like reling on an electric pump for a daily driver.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
