CHECK ENGINE LIGHT??
Postby 92 D/UNIT » Mon Jun 11, 2007 4:55 pm
Whats up with that? i didnt even know 92s had a check engine light, can anybody tell me why the lights on or where to look?
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby TOMTOM » Mon Jun 11, 2007 7:55 pm
Would first look under hood. Somthing left un hooked? alt charging, spedo working? if everthing looks ok it's time for a scan tool. a good mec. shop will have one as well as auto-shome(hopfully one of your pals). if not let me know i may be able to get you hooked up. I know a guy that knows a guy.
TOMMY (O'YEA WELCOME BACK)
93 CLUB CAB LE SHORT BED 209,000 MILES AUTO/OD 3.54 GEARS 4" TURBO BACK EX NO MUFFLER P7100 PUMP MODS B/D INJECTORS 13.55@99 MPH 440HP 967TQ ON #2 ONLY. PSD INTERCOOLER,BD SUPER B TURBO)47RE FULL MAN SUNCOAST TRIPLE DISC
TOMTOM
Postby Philip » Mon Jun 11, 2007 8:52 pm
Cycle the key on and off three times. Leave it on the third time. Count the number of flashes the check engine light gives you. These will be the error codes. It will be a series of flashes with a small pause between numbers. If memory serves me right 12 is the start test code and 55 is the end code. We need the numbers in between.
Postby Greenleaf » Tue Jun 12, 2007 9:28 am
My code, 56
Translates to; "boost signal out of reference"
:shock:
Greenleaf
tech specialist/mod
Postby dpuckett » Tue Jun 12, 2007 9:00 pm
Oh brother....... :roll: :roll: :roll:
