CAPPED PISTONS
CAPPED PISTONS
Postby BEARKILLER » Fri Jun 15, 2007 8:41 pm
I was watching a special on the ALCO 628 CENTURY locomotive.
During the show, the narator stated that the first several units released suffered from piston burn-through, due to the turbo and other variables.
ALCO took them back in and installed CAST-IRON capped pistons that could withstand the excessive heat levels, without melting.
Could/has this been done in our engines??
If so, what was the outcome??
Thanks.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby CAJUN 93 » Sat Jun 16, 2007 6:20 am
i don't know about the capped idea but there are several companies that offer coatings to protect the pistons. i'll dig around and see if i can find some info.
daryl
CAJUN 93
Postby KTA » Sat Jun 16, 2007 7:31 am
Many large diesels use a steel topped 2 piece piston. The crown is steel and the skirt is aluminum. Current trends are to do away with the aluminum skirt and use a solid forged 1 piece piston with very narrow skirts. The steel pistons are very heavy and therefore aren't good for high rpms like the cummins turns, yes 3500rpm is alot for a big diesel, most steel top applications are 2500rpm and down because of the weight.
Postby BEARKILLER » Sat Jun 16, 2007 9:43 pm
Maximum RPM on the big ALCOs is 900 RPM.
Idle is 300 RPM.
I guess that would explain their ability to run the heavy pistons.
BEARKILLER
