Extracting and replacing a twisted power screw...
Postby Begle1 » Fri Jun 22, 2007 5:41 pm
So this guy named Ishmael that I kind-of know was tightening the full power screw on his pump, and it twisted off...
So, how would Ishmael go about extracting the remains of the screw out of the IP? And where could Ishmael find a new screw? Part numbers?
Postby PToombs » Sat Jun 23, 2007 5:23 pm
Yer buddy is going to take the top off the pump, and screw it out from the inside! I think you..eeerrr, he tightened it up to the shoulder where the o-ring is. :shock: I would suspect the local Bosch dealer is going to have one right on the shelf (maybe!) (hopefully!) :wink:
Sorry, I don't have a part #. :oops:
Postby sdstriper » Sun Jun 24, 2007 4:06 pm
Schematics and p/n breakdown I have say's it's not a service part...
sdstriper
Postby bgilbert » Sun Jun 24, 2007 6:22 pm
sdstriper wrote:Schematics and p/n breakdown I have say's it's not a service part...
But it is available via Bosch. Scheid Diesel can get you one.
Bill Gilbert
bgilbert
Postby mhuppertz » Thu Jun 28, 2007 8:12 am
Also any pump rebuild shop will have cores laying around and will give you one.
mhuppertz
Postby wannadiesel » Thu Jun 28, 2007 4:40 pm
If it's not leaking and it's not running away, Ruprecht could leave it as is. :wink:
Best dyno: 408/844
wannadiesel
diesel guru
