by CumminsPower59 » Thu Sep 15, 2011 6:52 pm
Pete, the wecker was originally not armored, the add on armor kit comes painted tan already. We had several wreckers that had the woodland camo pattern, and tan cabs. Two wreckers had gone through rebuild and got a fresh coat of tan paint. Mine, originally was painted tan, it was built in 1991, alot of new trucks that year came out tan since we were in that part of the world then too, but had been painted all green at one point or another. Most of our wreckers were a hodge-podge of different years and what not.
Tacoclaw, the wrap in the fuel tank is a fire suppression kit, it has dry chemical fire suppression powder in it...it's supposed to work, but it always ended up being a pain in the arse to work around. One of our truck drivers operates caterpillars on the civilian side, it was fun watching him run those machines. We got a little bit of time to run them, funny thing is that when you are in the operators seat, you can't see a thing except the bottom corners of the blade. The M1000 trailer is quite the piece, as it self steers when hooked to the HET. It has a wedge that is behind the kingpin that fits between the ramps on the fifth wheel. The wedge is mounted on a plate and that plate is attached to two hydraulic cylinders. When the cylinders get pressure on one side or the other from the wedge being moved, it sends that pressure to two more cylinders at the rear of the trailer. From there, it is transfered by linkages that progressivley pivot four out of five of the axles on each side. Each axle, or bogie, is progressively controled so the trailer smoothy turns, so the rear bogies, #5, will be at full turn, while #4 will be a bit less and so on and so forth. #1 is barred in place and doesn't turn. The whole truck and trailer can turn so sharp it's crazy. Unlike conventional tractor trailer setups, when turning a corner, you don't have to swing wide. You just cut the corner as if you were driving a bobtail. The trailer does the rest and swings out, instead of cutting in...
