Tow with a locker ??
Postby tampabayBill » Thu Aug 23, 2012 8:15 am
I posted this in the chassis section but thought what the hey I'll try here too. So does anyone tow with a locker, how does it effect handling. I tow a 35ft travel trailer and am thinking about this, really want a tru-trac but they don't seem to be available. Any info positive or negative appreciated.....Bill
Twins coming soon!
tampabayBill
Re: Tow with a locker ??
Postby skilletky » Thu Aug 23, 2012 2:00 pm
i posted on the thread in the chassis section, but ill post here too. i forgot to mention about mine, if you let off the pedal and cruise, then give it some go, when the locker locks, it makes the truck kinda pull to the left. this may just be a problem with my truck. i cant figure out why it does it.
skilletky
