Serp. Belt and tensioner pulley question
Postby peobryant » Wed Oct 03, 2012 2:41 pm
I was replacing my alternator today (again...) and as I was putting the belt on the grooved part of the tensioner (looks like the same material as the belt) slipped off and I can't for the life of me find it. So, does it absolutely have to be there and if so, where can I find a new one? I need an answer fast otherwise I probably won't make it to S.O.P. Just my luck too. I'll get a picture if no one knows what I'm talking about.
Thanks.
Re: Serp. Belt and tensioner pulley question
Postby peobryant » Wed Oct 03, 2012 3:00 pm
I just took those. Where I'm pointing in the first picture had a grooved rubber belt on it that had disappeared.
Postby cmann250 » Wed Oct 03, 2012 4:11 pm
I'm not sure what's missing. My pulley is completely smooth, no grooves on the edges.
Postby PToombs » Wed Oct 03, 2012 4:44 pm
Parker, what you were seeing was the inside of the belt. With AC it comes off the crank pulley, around the tensioner, then back down under the AC compressor, and straight up to the alternator. Back down under the water pump, up over the fan, back to the crank.
Some tensioners have grooves, most don't that I have seen.
Postby peobryant » Wed Oct 03, 2012 5:19 pm
PToombs wrote:Parker, what you were seeing was the inside of the belt. With AC it comes off the crank pulley, around the tensioner, then back down under the AC compressor, and straight up to the alternator. Back down under the water pump, up over the fan, back to the crank.
I was wondering why there was so much slack. :lol:
I'm officially an idiot (as if you didn't know already) and I appreciate the help. Hopefully this new alternator will work and I'll be able to make the drive.
Postby cmann250 » Wed Oct 03, 2012 5:51 pm
Electricity is just an accessory with a 12v :lol: Pull cable FTW
Postby RumbleFish » Wed Oct 03, 2012 5:51 pm
Hey no worries, it happens to everybody. At least it was minor and didnt cost you anything!
