Nitrogen filled tires
Postby bgilbert » Fri Mar 28, 2008 2:20 pm
What's the story on nitrogen filled tires? I can get unlimited nitrogen cylinders at work. Boss told me he's been filling his with it for the past few years. Says tire shops charge extra for this? Nascar uses it? Thought I'd throw it out here, too lazy to google it :lol: .
Bill Gilbert
bgilbert
Postby nooblet » Fri Mar 28, 2008 2:50 pm
Airplanes use nitrogen in tires because of the altitude factor, I didn't know anyone used them in normal tires. I would assume it has something to do with heat, but thats just a guess.
Chris
nooblet
Postby PToombs » Fri Mar 28, 2008 5:24 pm
It's supposed to leak out slower. Something else too, but I can't remember what. :oops:
Postby cummins king » Fri Mar 28, 2008 8:44 pm
we use nitro in alot of our tires, the main purpuse is the dont change with weather like air does, our low pro tires would go flat if they didnt have nitro just because of the pressure drop
dealer charges a one time charge of 40 bucks and you get free unlimeted refills, even if you change a tire, get a flat, ext ext
93 4X4 auto
cummins king
Postby BC847 » Fri Mar 28, 2008 8:47 pm
FYI ~ air is 70% (+/-) nitrogen. ;)
Postby cummins king » Sat Mar 29, 2008 5:01 am
are you sure its that much i thought it was 30%
93 4X4 auto
cummins king
Postby cummins king » Sat Mar 29, 2008 3:59 pm
sorry my bad Air is made up of 80% nitrogen and 18% oxigen, and the rest is made up of my tail pipe, :lol:
93 4X4 auto
cummins king
Postby BEARKILLER » Sat Mar 29, 2008 5:45 pm
For normal purposes, paying for Nitrogen to be put in tires is a big joke.
There might be some slight advantages to use it in highly sensitive applications, but the advantages would be so little that they would have to be scientifically calculated, kind of like buying the water-heater that gives you a .06% savings in electricity.
If you can get Nitrogen for free, and can't find any better use for it, then go ahead and use it; but, if it is gonna cost money, then just use plain old FREE air and keep the money in your pocket.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby cummins king » Sat Mar 29, 2008 6:43 pm
i would happen to disagree, we have a benz with low pro and a van with low pro and if they dont have nirto in it in the winter they will go really low, to low to drive
93 4X4 auto
cummins king
Postby bgilbert » Sat Mar 29, 2008 6:55 pm
BEARKILLER wrote:If you can get Nitrogen for free, and can't find any better use for it, then go ahead and use it; but, if it is gonna cost money, then just use plain old FREE air and keep the money in your pocket.
The only thing it will cost me is a regulator. I have one on my oxygen cylinder but rather not switch them around when needed. I have an extra 25ft air hose and 25ft coiled air hose I could use. I have 5 Dodge trucks and I'm always checking/setting tire pressures. If I can come up with a cheap regulator I might try it.
bgilbert
Postby PToombs » Sun Mar 30, 2008 3:15 pm
Why bother? You can only drive 1 at a time! :rock:
Postby cummins king » Sun Mar 30, 2008 5:45 pm
:mrgreen: :jumpsmile:
93 4X4 auto
cummins king
Postby Philip » Sun Mar 30, 2008 7:31 pm
The main reason you see race teams use nitrogen is because it does not expand with heat. You start with 32 PSI on a cold tire it will end up around 35 to 40 PSI after it warms up. Using nitrogen it doesn't climb on pressure.
Postby PToombs » Mon Mar 31, 2008 3:30 pm
Yeah! That was the other reason! :oops: Thanks Philip! ;)
Postby dpuckett » Wed Apr 16, 2008 3:08 pm
bgilbert wrote:I have 5 Dodge trucks and I'm always checking/setting tire pressures. If I can come up with a cheap regulator I might try it.
Try buying some new tires now and again, and you wont have that problem, Bill. The junkyard isnt the best place to get 235/85-16 tires. Those little bars between the tread arent added traction- they mean the tire is worn out. :lol:
I laugh at a guy at work who swears he gained some fuel mileage with nitrogen in his tires. I told him I have 78% nitrogen in my tires. He asked how, and I told him plain air. He aint the brightest bulb in the chandolier.
DP
