IF IT AIN'T BROKE, DON'T FIX IT!
Maybe I'll get it done over spring break in April. I hate to disappoint you folks
cmann250 wrote:I nearly caved to the peer pressure today. I almost put in my Suncoast converter. I removed all the cooler lines, shifter linkage, TV cable, inspection plate, and park switch wiring. I then proceeded to smack myself on the forehead and thought, out of the last +/- 365 days, it's been down for maybe 10. It's getting borderline reliable
Maybe I'll get it done over spring break in April. I hate to disappoint you folksI've got it to the point where it's fun to drive even with the valet switch closed, which is how it's set 90% of the time. Maybe I'm lame and I like a 200 hp truck
cmann250 wrote:...Maybe I'm lame and I like a 200 hp truck
dazedandconfused wrote:Still more power then a Powerstroke puts out.
Mark Nixon wrote:Oh yeah, check the parts section, there's a cure for your low-horsepower blues listed there.![]()
dazedandconfused wrote:Oh my old man has a psd and it cant get out of its own way.
cmann250 wrote:...I'd like to have a G56, but the likely hood of that happening isn't good...
cmann350 wrote:...Whether I bomb it like my Dodge is to be seen. BUT, before some people let out a sigh of relief, I'll keep my Dodge for as far as I can see. I can't afford to get rid of it. It's worth nothing, it's cheap to operate, and it does 95% of everything I could ask for in a truck. I'm here to stay.
dazedandconfused wrote:Yeah dads is a 97 with 90k miles and its a slug. 4x4 F350 auto with a 12' flatbed. I can give him a truck length head start and out run him in my 24V 5 speed truck.
ellis93 wrote:Put money on the turbo pedestal being bad or the HP oil pump is weak,two VERY common failures on those. Either one will make it a turd,well......more of one
Mark Nixon wrote:
At least you have the sense to realize that, even stock, the superior truck is the Dodge and it's already outlived many PowerChokes and IDIs, not to mention the disasters GM built, with more of each getting justifiably flattened every day.
