2016 BS and Chat Thread!
Re: 2016 BS and Chat Thread!
Postby PToombs » Sun Jan 24, 2016 1:48 pm
DF, that would be fine, Thanks much! Can you measure ground clearance too?
Cougar, is that normal for you guys, having earthquakes? Hope everyone is ok
Postby spencerdiesel » Sun Jan 24, 2016 4:19 pm
:shock:
H1C/18
Muffler delete
spencerdiesel
Postby Philip » Sun Jan 24, 2016 9:38 pm
cougar wrote:Trade you your snow for my 7.1 earthquake.
I went threw a 6.7 in AK in 78. That kind of shakes the building a little. :lol:
Went threw a 6.9 in 73 on Guam. :shock:
Postby cougar » Mon Jan 25, 2016 10:03 am
Fairly normal around here. No one seriously hurt or killed. Other than some houses that got torched from a gas main that broke, damage was at a minimum. Grew up on the San Andreas, so I'm use to it.
01 2500 "the work truck".
cougar
Postby Remps » Mon Jan 25, 2016 7:50 pm
1.57 per litre where I'm at. Put in 125 litres in my truck for $206. :shock:
Postby DodgeFreak » Mon Jan 25, 2016 8:00 pm
Lowest spot is 1" highest is 4" and 6 3/8" with head rest.
Postby DodgeFreak » Mon Jan 25, 2016 8:02 pm
Let me rephrase, 1 in to the ground at the lowest point. 4" from the ground to the top of the highest point and 6 3/8 from ground to top of head rest.
Postby PToombs » Tue Jan 26, 2016 5:54 pm
Thanks DF, appreciate it. Looks like I won't be getting the bigger wheel one, I think it's too tall, (wide? thick?) to fit in the cabinet. :(
Postby Philip » Wed Jan 27, 2016 8:25 am
Hea Dman you coming down to MM's event this summer??
Postby RCCUMMINS89 » Wed Jan 27, 2016 6:59 pm
" I refuse to do compounds........too many issues 1. they cost alot and 2. you can't tow with compounds, always heat issues. I want 600hp with a single, that way I can tow". So....... you want 600hp with your 12 valve, with a single, for a tow mule? "Yes".
I'm checking out for the day.
Postby fatty » Wed Jan 27, 2016 8:28 pm
There are some people out there, if they here something from someone they consider to be an authority, will believe it without question, and wont be convinced otherwise. It's very annoying at times
Postby DMan1198 » Thu Jan 28, 2016 2:57 pm
Philip wrote:Hea Dman you coming down to MM's event this summer??
If it coincides with my days off absolutely
Postby DMan1198 » Thu Jan 28, 2016 4:12 pm
And if I feel comfortable with the reliability of The Roo Hunter I'll even drive it out
Postby spencerdiesel » Thu Jan 28, 2016 5:26 pm
I know an individual who insists oil is thin when cold and gets thicker with heat.......because that's why its called "multi weight" :pale:
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Fri Jan 29, 2016 5:25 pm
Which is true..... sort of. It has less resistance when cold, but retains viscosity when it's warm.
