Parker's Got a New Job! (Find me an '89 D250)
Re: Parker's Got a New Job!
Postby cmann250 » Fri Nov 23, 2012 11:29 am
I don't have pics of the F250, but anyways :lol:
With my truck, I've netted 5.5k with my 460, 6k for a pick-up, and 10-12k+ with hay all on the same single tandem 24' G/N several times each. Would I put two 4320s or two 1 tons on it? No, that's just hard on any truck and that's what a semi is for. I'm comparing my truck to a '00 F350 CC DRW and the difference isn't worth 2.5K on the pick-up and 2 more drive tires.
I never notice sway (side to side right?) and the trailer doesn't push me that bad. However, I do like to know it's back there. I've racked up probably 500 miles dragging that G/N and it's a piece of cake to tow. No problems towing that F250 home and I had hills and curves there. I took an easy, banked 90* turn on a 2 lane state highway at 55 and I didn't feel a squirm. A dually isn't worth it to me where I'm at, under 15k net usually. Over 15k, I don't know if I've ever been there, it may be different.
Postby peobryant » Sat Nov 24, 2012 11:34 am
Well, I lied. I've decided I want to get an '89 D250 (don't care if it's a manual or auto) as a daily driver now because I can't find a Subaru that's worth a damn at anything close to a reasonable price. So, be on the lookout for a cheap, 2wd truck for me. I wouldn't be against a drive if the truck is decent. Basically I want it to be reliable and cheap, that's it. I don't care about options, looks or anything like that. I'd appreciate it if you guys would be on the lookout for me, and if you're close enough take a look.
Thanks.
Re: Parker's Got a New Job! (Find me an '89 D250)
Postby bmoeller » Sat Nov 24, 2012 2:09 pm
My 93 W350 dually gets basically the same mileage as the 92 W250 I had.
I don't need a dually most of the time, but when I do, I can pull whatever I want, and not worry about it. Gets better mileage than some Ford Rangers I've driven! :P 8) The 93 gets better mileage than my 97 and 99 3500's did, even towing. 3.54's may have helped, had I swapped them over from 4.10's.
More stable too. Especially with bumper pull trailers. One I've used several times had tail wag really bad. :roll:
As for tires, All 6 (235)on my dually were $300 cheaper than the 4 (315) I put on the 92. So, tire size does affect that.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby cmann250 » Sat Nov 24, 2012 4:00 pm
bmoeller wrote:As for tires, All 6 (235)on my dually were $300 cheaper than the 4 (315) I put on the 92. So, tire size does affect that.
Wide tires is another thing I just don't get. I doubt I'll ever have any wider than a 235. There's no arguement that wide tires eat up mileage. I call anything wider than 235s ag flotation tires :lol:
Parker, http://tippecanoe.craigslist.org/cto/3380705945.html I know this guy and he's even a member of this site. I've not seen this truck, but if you value my opinion, I'd look at it. It's just north of me.
Postby peobryant » Sat Nov 24, 2012 5:10 pm
That is EXACTLY what I'm looking for, thank you. I'll give the guy a call and if you aren't too terribly far from it I'd really appreciate you taking a look at it. Lafayette, IN is about 3 and a half hours from me but I'd be happy to drive that distance for a good truck.
Postby Hansen01 » Sun Nov 25, 2012 12:44 am
:( Must be a 2wd thing :lol:
That means ive always had flotation tires 285's all the way :twisted:
Under construction...
Hansen01
Postby bmoeller » Sun Nov 25, 2012 12:57 am
bmoeller
Postby bmoeller » Sun Nov 25, 2012 12:58 am
The 315 sized rubber was already on the truck, as was the lift. First lifted truck I've ever owned. One great thing about the 35" rubber and 4" lift....... I can sit up under it, in many places to work on it. No need for blocks under the front wheels for the 5 gal bucket to change the oil either. :lol: And, another great thing is, that with about 50psi up front and 40 in the rear, it softens the ride over the 235 rubber. :) But, the Cummins doesn't make the front end sink in my gravel drive after a heavy rain either. ;)
I do need front springs on the 92 in the worst way though. They are wearing into each other pretty good and sagging pretty bad.
bmoeller
