My "new" 1993 project/daily driver! :D
Re: My "new" 1993 project/daily driver! :D
Postby bmoeller » Sun Dec 02, 2012 5:11 pm
42187 and 42188 are the 2 options I cam up with, from various sites. Including Dorman. 1 kit includes enough for all 4, and the other is just the 2 of them.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby bmoeller » Mon Dec 03, 2012 8:05 pm
The passenger side door OPENS! :D Pulled the seat out to swap the donor seat in (other has some broken springs under it), and had enough room to get in there with a long skinny screwdriver to pop it open. The latch was gummed up REALLY BAD! Got it cleaned up enough and use chain lube on it. opens and closes like a new one. Stays shut, without any rattles either! :D I'm a happy camper. Wife ought to like that too. ;)
bmoeller
Postby Farmboy92_2009 » Mon Dec 10, 2012 1:29 pm
sounds like your making quite a bit of progress with the truck. hope all is well. i see you finally bought a crew like you've wanted to do for some time now. gna swap the motor n trans out of the 93 to the crew cab? anyhow glad to see your gettin it fixed up. good luck
tater
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
Postby bmoeller » Sat Jan 05, 2013 8:40 pm
Well, the door latch acted up the following I posted in here the last time. So, having a junk pass door on my Cummins donor, I stole it out of that one, and put it in the 93. Working good now. :D
bmoeller
Postby bmoeller » Thu May 02, 2013 8:04 pm
Looks like the fuel pump did the trick. Truck hasn't laid down on me again. :D 'Bout 1000 miles on it, since I put the pump on, not that long ago. The extra power is nice. Kinda cool (and also pathetic), that this old girl feels almost as strong as the 99 I had, with an Edge Juice w/ Attitude on it with the wire tapped. I suppose the 93 having 3.55 gears, vs 4.10s helps a bit in the butt-o-meter dept.
bmoeller
Postby PToombs » Fri May 03, 2013 5:34 pm
Nahhh, it ain't the gears. It's the vastly superior VE pump that does it! ;)
Postby bmoeller » Fri May 03, 2013 7:33 pm
VP was junk, too. ;) Had 0psi going to it when i bought the truck. Sure that helped.
bmoeller
