Re: I want pictures of your trucks
Postby 91bluecummins » Wed Nov 23, 2011 7:31 am
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Postby 01hillbillycummins » Fri Feb 03, 2012 2:39 pm
^ so thats what my paint used to look like :mrgreen:
this thread needs a bump
1990 w250 Denny T II pin, 3200 spring, BHAF, DE 4" TBE, 5" lift, 37" toyos, kelderman air ride, 75 gal aux fuel tank
01hillbillycummins
Postby 91bluecummins » Mon Feb 06, 2012 6:35 am
91bluecummins
Postby Gots_a_sol » Mon Feb 06, 2012 8:16 pm
Not much to look at, but it is slowly coming around.
Dragged home a parts truck yesterday (2/4/12) and is the most recent pic I have taken of it.
This was how it looked the day I bought it
-Joe
Gots_a_sol
Postby ramtough1993 » Wed Feb 08, 2012 3:47 pm
By spring the truck will be transformed.
1993 Dodge Power Ram 150 4x4, 5.2L Magnum, Automatic Transmission, Work Special Package, Currently mostly stock
ramtough1993
Postby singlesmoker06 » Wed Feb 15, 2012 6:58 pm
91.5 d250 auto. $800 truck just for fun, 3200 spring, big injectors, big turbo, now have money out of pocket ....
SMOKED OUT DIESEL PERFORMANCE
817-578-5308
singlesmoker06
Postby CumminsPower59 » Thu Feb 16, 2012 9:18 pm
From SOP #8...
Postby 01hillbillycummins » Sat Feb 25, 2012 7:59 am
01hillbillycummins
Postby bigbill105 45 » Sun Mar 04, 2012 2:27 pm
bigbill105 45
Postby 91bluecummins » Sun Mar 04, 2012 6:48 pm
91bluecummins
Postby autocar56 » Sun Mar 04, 2012 7:06 pm
Here is mine
91.5 4x4,5 speed, pump timing 1/16, fuel screw 1 turn, ground down pin, k/n air filter , stacks, 160,000 miles
autocar56
Postby 01hillbillycummins » Fri Mar 23, 2012 11:03 pm
new dual whips
01hillbillycummins
Postby 1stgenblowingsmoke » Sat Mar 24, 2012 11:15 pm
90 LE 250 reg cab 4x4 5 speed getrag. Fuel screw turned to factory stop, throttle rod mod, 3.5in flow through exhaust, #75 fuel pin rotated, HX-35 waiting to on along with an intercooler.
1stgenblowingsmoke
Postby bmoeller » Sun Mar 25, 2012 10:07 am
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Black93 » Tue Mar 27, 2012 8:20 am
I don't know when it will be this clean again. :lol:
Black93
