2015 BS and Chat Thread!
Re: 2015 BS and Chat Thread!
Postby BC847 » Wed Dec 16, 2015 6:09 pm
The genius of today's youth never ceases to amaze me. :roll:
My chit puts 489HP to the ground, gets 16ish mpg overall, reliably beats-up on folks at the dragstrip on Thursday, just to go round trip to the coast the following weekend . . . . WITH the fully functioning:
- Grid heaters.
- Fuel heater.
- Silencer ring.
- Air filter housing.
. . . .. and so on.
Why the phak is it that any time something sneezes, one must delete it? A thousand fly's talk like Chit tastes good! WTF?
Postby oldestof11 » Wed Dec 16, 2015 7:42 pm
Long time no see.
2nd shift training and ATT work has me all sorts of behind.
I wouldn't go to Garmons shop personally. Swole (on CF Philip) is his biggest cheerleader and side kick. Cop too.
Love Facebook. Paraphrased convo from just yesterday. "Man, I was told no more than 5psi inlet pressure by my pump builder"
Me: your pump builder is way behind the times
Him: *names well known builder*
Me: LOL ok.
WHY MUST YOU LIE?!
Postby fatty » Wed Dec 16, 2015 8:45 pm
Garmon helped out Big Swole a few times so now BS feels he owes him for the rest of his life.
Postby DMan1198 » Wed Dec 16, 2015 9:09 pm
So I actually did something to my 1st gen today. Media blasted my secondaries turbine housing, and manifold. With all the soot, and rust off of the turbine housing I've found a number of cracks on the inside. Now I'm not quite sure what to do with it
Postby Farmboy » Thu Dec 17, 2015 6:04 am
Any big star war fans out there.. I'm not a huge one personally, but this is still way cool..
Type or copy paste "A long time ago in a galaxy far far away" into a google search and wait for it..... 8)
Farmboy
Postby DMan1198 » Thu Dec 17, 2015 9:38 am
That is quite cool what happens
Postby matthewh » Thu Dec 17, 2015 2:04 pm
matthewh wrote:Image
Its a 580B. Other than the pictures, the ads pretty vague. I'll prolly swing up Friday before work or Saturday morning and at least check it out. Was really looking for a trailer they had listed, and came across this instead
Had some free time before work to check this tractor out. Said they'd take $3000 to get it off the lot. Has alot of new hydraulic hides, tires both front and rear look almost new. Kicker, needs an engine rebuild. This place couldn't even get it to run, previous owner said it ran, but was "soft" which I take since these guys locked up the starter trying to get it to run means has zero compression.
Trailers didn't even pan out either. One was only a 12' deck, the other had a bent axle, and it was the old Dayton style, but not MH axle, so you'd have $1500 into new axles. :cry:
matthewh
Postby spencerdiesel » Thu Dec 17, 2015 4:54 pm
What's Star wars? That's a joke, but that is awesome....
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Thu Dec 17, 2015 5:43 pm
And it gets worse, that's not a 580B (mid '70's), it's a 580CK, late '60's machine. If you could get it for about $1000 or 1500 it may be ok with a bad engine, but it will cost a few grand to rebuild it so you're back to close to or more than it's worth. As soon as I saw the pic I knew it wasn't a "B". IMO, you should pass on it and look for a "C" or "D" model for about $4k, they are way more advanced and rugged. That one is actually a farm tractor with a loader and backhoe, like most brands, that's how they started to build backhoes.
Postby matthewh » Thu Dec 17, 2015 5:48 pm
Ha, noticed it was a CK as well when we pulled in looking for it. Its at a Kubota dealer, only place around to buy tractors and implements, and they dont deal. Said they'd mess with it this winter if they had time. I just noticed the price and it was in my range. There's a few around, JD's, Fords, etc ill keep my eye out
matthewh
Postby PToombs » Thu Dec 17, 2015 5:50 pm
Good luck! I work for a Case CE dealer, so if you have questions lmk. ;)
Postby DMan1198 » Thu Dec 17, 2015 7:30 pm
I finally got around to fixing my cold pipe (leaked like a sieve) and figured out why it was impossible to run a bead on that material. Simply put I didn't have enough shielding gas. Adjusted that, and she worked like a charm
Postby RCCUMMINS89 » Thu Dec 17, 2015 9:22 pm
Facebook, is my hero
Other guy - My efi pulled 16 mpgs my smarty 22 my edge 26 mpg smarty had the most power but the highest egts
Me - Sounds like overhead mpg to me.
Other guy - No i hand calculate snd my overhead is pretty accurate kinda funny my 04 would register like 22 and get 14 when pulling
Other guy - I drive cross country all the time i have roughly 260k miles if its super cold out i can get up 28 doing 63mph
Other guy - Stock solid 20s ....15s when pulling
Other guy - I also had 1996 12 valve got 39 mpg had over 600k miles lol had a gear splitter 5 spd with gear vendor
So............If this were real life, I would have that blank stare.
Postby fatty » Thu Dec 17, 2015 11:57 pm
That's what I meant when I said that I just don't understand why people flat out lie online. Those numbers are impossible!!
Postby RCCUMMINS89 » Fri Dec 18, 2015 12:22 am
Uh, yea.
