Did get the electrical wired in for the trailer. Just need to see if the controller will work with the brakes. Controller "seems" to be doing what it supposed to. Just need to hook up a trailer and find out for sure. Found out what 2 of the extra switches on my knee bolster towards the bottom of the dash were being used for. One to run the aux power terminal and the other to the line that would charge the trailer battery for the breakaway. They still work too.
Got the mounting plate for the tranny support plate welded up a little bit ago. The bad motor mount probably has a lot to do with it.
Did find that the grease seals on the rear u-joints are no good, so I'll be needing to replace the crosses as well.
Generally takes me a year to get as much done as I have right now in the past few weeks.
