2015 BS and Chat Thread!
Re: 2015 BS and Chat Thread!
Postby fatty » Sat Jan 03, 2015 10:42 am
You think you wife will let you lift it that much? :D
Postby RCCUMMINS89 » Sat Jan 03, 2015 10:48 am
Yes, she gave me the ok..... Because I told her, she is now getting a new car. :lol:
See the original conversation went like this.... "Hunny, I think I'm going to buy a common rail", to which she said "REALLY!". And then the next conversation went like this, "hunny, I think I want your truck.... want a new car this year?" to which she said "Wow, you're awesome".
This is how you get what you want, while the wife is actually excited about it.... ;)
Otherwise.... the original thing would of gone like this in her head..... "why does he get to drive a nice truck because of the company?"" is the company more important than me"
Postby DMan1198 » Sat Jan 03, 2015 10:49 am
Personally I'd go 6" since you want 37's
Did you get rid of those little SUVs?
Postby cmann250 » Sat Jan 03, 2015 10:56 am
I feel like I'm driving a monster truck since I have a leveling kit and 285s.
I don't think you want my opinion :lol:
Postby RCCUMMINS89 » Sat Jan 03, 2015 10:57 am
They will be gone.... because its winter, the wife is still driving the one.
Looks like the RC will most likely be down for the entire year of 2015, as major plans are in the works..... super secret squirrel stuff though. So don't ask.... but in case any one is curious.... it will still be ve, I'm not turning against that.
And with well over $6500 into this new engine so far, the project absolutely will be finished. NO worries, it just may be a full year yet again.
Postby AHineman » Sat Jan 03, 2015 11:00 am
Depends on what you do with it. Not a fan of lifted trucks for trailers or getting in the bed, etc.
Postby DMan1198 » Sat Jan 03, 2015 11:03 am
Great now I want to ask. I don't feel like mine is too big with its little lift, and stock tires. Didn't even feel like it was that big in Eric's RC,
Postby fatty » Sat Jan 03, 2015 11:04 am
Why the secrecy? If it's staying ve like you said, you can't possibly be breaking any records so who cares?
Postby RCCUMMINS89 » Sat Jan 03, 2015 11:06 am
Shoosh it..... I'm just saying that it is not going to be back together for a long time....
Postby DMan1198 » Sat Jan 03, 2015 11:09 am
Ve on an 8.3 with quadruple turbos, and a huge shot of nitrous, and water/meth maybe?
Postby RCCUMMINS89 » Sat Jan 03, 2015 11:33 am
I'm not talking about the fueling (as in, its secret)...... But most likely the front axle will have the knuckles cut and make a high pinion, and it may get a fully built 47 to handle the new power, as well as probably going with 1480 rear joints as to help with longevity with the angles. Suspension may or may not get changed to a full 4 link coil, potentially even coilover springs.
Postby DMan1198 » Sat Jan 03, 2015 11:56 am
It had better be a manual valve body so at least you're not letting it do the shifting for you too. I wonder if you could run an standard clutch rather than a torque converter. I know enough people that shift locked that it shouldn't kill it too easily.
Postby AHineman » Sat Jan 03, 2015 1:16 pm
What would be the point when you can run a switch to manually control lockup at any time?
Postby meby » Sat Jan 03, 2015 2:24 pm
tip of the day: before you freak out that your truck is running 21 volts - double check against a second voltmeter. Apparently I have a bad voltmeter - it showed over 16 volts with the truck not running. :evil:
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby oldestof11 » Sat Jan 03, 2015 2:46 pm
Why the lift? You can tuck 37's with a 4" lift. You aren't gaining ground clearance.
