by DMan1198 » Sat Dec 06, 2014 6:45 am
If you could find an H pump, and if you could it to put out in the 1000cc range I don't think it'd be nearly as problematic for spooling. Though something I was thinking of doing with The Roo Hunter to try and get into dpc was a 14mm p pump 6.7 with a 400/500 compound setup. Even if it took a bit to spool that amount of fuel would still get you some big numbers
