matthewh wrote:I just happened across it while surfing local Craigslist.
After doing some research, looks pretty easy to swap over, other than deciding whether to use the wastegate, and having some goofy intercooler piping, or tack welding it shut and clocking it to use the stock setup
oldestof11 wrote:I'm going to try uploading some tomorrow.
I'm keeping the wastegate and solenoid. Thinking of getting a Raspberry Pi or Audrino mini computer. Use it to have 3 adjustable setting. I'll need 2 outputs and 6 inputs. 3 setting would be Econ, Tow, and Race. All 3 would use TPS, MAP, and speed. For Econ, it would keep a valet closed and possibly using a solenoid to open the waste gate some. Less back pressure, more efficiency off boost.
Tow would use an additional sensor, EGT. Using a variable solenoid, it would limit boost to the AFC depending on EGTs and the other sensors.
Race would be an anti slip, full power setup. Using a setup similar to aftermarket cruise, a front wheel with a magnet would read actual speed while the computer compares it to the speedometer reference. This will have a determined amount of percentage slip. If it goes beyond a certain percentage, it will slowly close the AFC off until traction is gained again. Then it'll ramp the AFC back up.
cmann250 wrote:I'll have to read the sticky. Thanks guys.
This one is on a stand so it should be easy.
Levi! Glad to see you back.
Tacoclaw wrote:You could buy a new set of slicks, a jack, and an electric impact for the price of all that turbo stuff.
