Truck search
Re: Truck search
Postby oldestof11 » Wed Feb 22, 2012 4:38 pm
My next set of gauges are coming from these guys:
http://mcnallyelectronics.com/
I think 6 inputs in 3 gauges, 6 read-outs, would be just right for me.
Seem priced with the Autometers, not as bad as Glow-Shift...
Re: Truck search
Postby Tacoclaw » Wed Feb 22, 2012 5:18 pm
I'm showing $250 for their boost/pyro combo kit. Boost goes to 80, but what's up with only having 3 numbers for pyro?
Do the glowshift ones cost that much?
Here's what I had in my Dodge the first time, though it was a 35psi gauge:
Westach makes it, though their prices are up to about $300 for the gauge kit.
Re: Truck search
Postby oldestof11 » Wed Feb 22, 2012 8:54 pm
You can get it in Celsius or Fahrenheit. My guess is the *F is XX.X times 100.
Re: Truck search
Postby redneckroot » Wed Feb 22, 2012 9:14 pm
Posted in the wrong thread
redneckroot
Re: Truck search
Postby Mark Nixon » Thu Feb 23, 2012 9:14 pm
Just ran 2 tanks of fuel through the '96.
I got back-to-back 19 MPG with consistent speeds over 65!
530 miles per tank, 27 gallons to fill, exact same pump at the same station and both fills at the same level in the neck.
No, I'm not mad at this truck ONE BIT. :D
Re: Truck search
Postby 1STGENFARMBOY » Fri Feb 24, 2012 9:43 am
Thats what i got with my last P-7100 95 CC 5 spd 4:10's as far as i'm concerned
thats fine MPG for a truck that will pull what ever you hook up to it.
Re: Truck search
Postby ahale2772 » Sun Feb 26, 2012 12:41 pm
got her going, shifts nice and smooth, took 5 gallons of atf at this point :shock:
made the lines out of 1/2 stainless, bubble flares on the end. Parker pushlock for the jumper lines, original temp sender mounted in the line is relocated at the filter head (auto guru's, think I'll have any issue with the temp drop from the trans to there?)
cooler is wired up with a relay, with the sence wire going through the thermostatic switch.
all needs to be tidyed up, all temporay untill I get it registered and I know that the cooler is enough to keep the system cool.
mounted the cooler on the passenger side under the bed, upright
filter right in front of it
then down and over the crossmember
back into the trans
Re: Truck search
Postby PToombs » Sun Feb 26, 2012 5:46 pm
You should have turned the cooler a 1/4 turn, so the air flows over it. It saves on the fan by cooling naturally and helps in general. As for the fan sensor, I would put it coming right out of the trans, so that the fan kicks on as soon as hot oil is detected. It kinda gives the cooler a head start before hte hot oil actually gets there.
