2018 BS and chat thread
Re: 2018 BS and chat thread
Postby PToombs » Sun Jan 21, 2018 5:29 pm
It's also possible that the port is plugged someplace. I would pull the screw out and squirt some carb cleaner thru it and see if the fluid comes out. Usually you can see it coming out the front of the carb or into the venture.
Postby ellis93 » Sun Jan 21, 2018 7:17 pm
spencerdiesel wrote:Ran the 046 through a little locust today and got her good n warm. Got to be a touch lean in the cut for my liking so I richened the H screw a bit and no change. Richened another 1/4 turn and no change.....same WOT rpm whether the screw is bottomed or hanging out of the carb. L screw does what it should.
I rebuilt the carb last year and tuned both H and L accordingly. Anyone know why no change from the H screw at all?
Steps I'd take
1 remove carb
2 pitch it in the trash can
3 replace with 20$ eBay Chinese carb
4 live happy till next issue
5 rinse and repeat as necessary
Postby dazedandconfused » Mon Jan 22, 2018 9:01 am
Steps I'd take
1 remove carb
This is what Stihl is telling people except to buy one from an authorized dealer.
Postby 1STGENFARMBOY » Mon Jan 22, 2018 11:49 am
I usually don't have any trouble out of any of my Stihl saws, but my 28 yr old Craftsman weedeater has been giving me carb trouble for years, I did what Ellis said and bought a carb off e-bay, wish I would have done it 10 years ago, I could have saved days of combined time.
Postby DMan1198 » Mon Jan 22, 2018 3:57 pm
Well I had an interesting day yesterday. I pulled a p pump off a 5.9 that’d been overheated, pulled another p pump off a running 5.9 in a mulcher, and put the first pump into the mulcher. I was a little scared the timing wouldn’t work out because the timing gears threaded holes weren’t even close to where they were on the other engine, but it all worked out fine. It was actually one of the nicest days of work I’ve had in quite a while. The eightysomething dollars an hour was a plus too.
Postby dazedandconfused » Mon Jan 22, 2018 5:21 pm
Okay so I'm working on the Excursion again. I won't be able to run the heat exchanger in the factory location. With the Ford it ran the transmission into a small cooler then the radiator. I'm thinking of running it like this and then throwing on my big cooler with the fan. Do you guys think the radiator will pull as much heat as the heat exchanger?
Postby ellis93 » Mon Jan 22, 2018 7:51 pm
1STGENFARMBOY wrote:I usually don't have any trouble out of any of my Stihl saws, but my 28 yr old Craftsman weedeater has been giving me carb trouble for years, I did what Ellis said and bought a carb off e-bay, wish I would have done it 10 years ago, I could have saved days of combined time.
Yep......seems to work well and no fiddling with tiny ass screws or orifices that won't open......I know everyone hates that lol
Postby peobryant » Tue Jan 23, 2018 1:27 am
Alright, so I need a new steering box. I've been looking at both Redhead Steering Gear and Blue Top boxes, anyone have experience with them? I've read that the guy who runs or owns Blue Top used to work for Redhead and they are essentially the same other than price. I'm also more than likely going to do a Borgeson steering shaft while I'm in there, it seems like the best time to do it.
Luckily it has warmed up here, it was in the mid 50's today and it felt fantastic. Hopefully that is the last of the cold weather.
Postby spencerdiesel » Tue Jan 23, 2018 4:33 am
I actually get tickled tuning carbs. I swear I got some adjustment out of the H after I rebuilt the carb, so hopefully it is some junk I can clean out.
While I do only run eth free fuel, the saw has sat probably 10 months since I last put her in the wind
I go out of my way to have screws to turn, I took the oem carb of my stihl pole saw that only had a L screw and stuck one on it with more screws :bom:
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Tue Jan 23, 2018 5:31 pm
dazedandconfused wrote:Okay so I'm working on the Excursion again. I won't be able to run the heat exchanger in the factory location. With the Ford it ran the transmission into a small cooler then the radiator. I'm thinking of running it like this and then throwing on my big cooler with the fan. Do you guys think the radiator will pull as much heat as the heat exchanger?
Pretty sure it goes to the radiator then to the small cooler, at least it does on an F550. I think it will be fine with the fan cooler added on. Remind me, what trans are you using again?
Postby ellis93 » Tue Jan 23, 2018 5:38 pm
spencerdiesel wrote:I actually get tickled tuning carbs. I swear I got some adjustment out of the H after I rebuilt the carb, so hopefully it is some junk I can clean out.
Don't know about you......But my time is worth a hell of a lot more than dicking around with a 20$ carb is worth to me. :lol:
Postby spencerdiesel » Tue Jan 23, 2018 7:38 pm
This is true from a productivity standpoint, but Its an interest of mine. Still better than candy crush I guess :D
H1C/18
Muffler delete
spencerdiesel
Postby dazedandconfused » Tue Jan 23, 2018 8:15 pm
47rh is what's in it. It goes through the radiator and a cooler in front. I'll probably upgrade that cooler too.
Postby 1STGENFARMBOY » Wed Jan 24, 2018 9:38 am
peobryant wrote:Alright, so I need a new steering box. I've been looking at both Redhead Steering Gear and Blue Top boxes, anyone have experience with them? I've read that the guy who runs or owns Blue Top used to work for Redhead and they are essentially the same other than price. I'm also more than likely going to do a Borgeson steering shaft while I'm in there, it seems like the best time to do it.
I am normally to cheap to buy something good, but I did spring for a redhead box 5 years ago or so and I like it alot.
Postby ellis93 » Thu Jan 25, 2018 4:50 am
spencerdiesel wrote:This is true from a productivity standpoint, but Its an interest of mine. Still better than candy crush I guess :D
Probably so.....I don't play games either. Only fun time I have I use to put together ammo and shoot it.
