2015 BS and Chat Thread!
Re: 2015 BS and Chat Thread!
Postby ellis93 » Fri Mar 27, 2015 9:54 am
The ones in the ppump engine will lay it down on the pavement if you mash on the skinny to hard. I just wish I could have realized their full potential in that engine. I haven't even really added a whole lot of fuel yet :?
The weird thing with the seven hole injectors are that even tho every engine,ppump,ve and vp,all have the same combustion chamber piston and I would guess comp. the only thing that I know of is the pop psi and the injection pressures of their corresponding pumps. From that and reading that jodo guys post of the 6.7 engine (running 320bar pressure with a ve) I think they'll actually work better in our trucks at higher pop psi. Say at the ppump and vp 265bar in our engines. I think that would totally clean up any idle haze. One one thing from there that would still hamper them.....upper rpm fueling.
Idk what the final outcome will be but I'm putting my setup together as it where is. I'm installing the pump,case,cover and running it on a stand before I do any injector work. If it sounds good them you and I will have to see just what the vp sticks will flow after a hone job.
Postby meby » Fri Mar 27, 2015 2:16 pm
peobryant wrote: I've already hit over 50mpg in this car before so I'm hoping 55mpg or so won't be out of the question now.
I hope you make it. 8) I've got a couple tweaks planned for the van this summer. I hope to hit 45 mpg myself. :mrgreen:
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby oldestof11 » Fri Mar 27, 2015 5:03 pm
Ike, whats up with the kid? I am sorry to hear about that.
ellis93 wrote:The ones in the ppump engine will lay it down on the pavement if you mash on the skinny to hard. I just wish I could have realized their full potential in that engine. I haven't even really added a whole lot of fuel yet :?
I have found literature stating new injectors should be popped at 270bar with a VE pump. Dodge has ours at considerably less.
Postby RCCUMMINS89 » Fri Mar 27, 2015 5:28 pm
Up to 278 BAR Jon
Postby ellis93 » Fri Mar 27, 2015 5:55 pm
RCCUMMINS89 wrote:Up to 278 BAR Jon
But is that with new springs? Maybe they try to account for wear in?
Postby DodgeFreak » Fri Mar 27, 2015 6:22 pm
Wheres the new job at Ike?? Also what I thought was an HE351cw....I think its some other breed...it measures out like a 341 with an electronic waistgate acutator....that is a let down lol...it does have a fresh kit in it. so thats a plus...I'll just buy a 351 wheel and throw my housing on it.
Postby RCCUMMINS89 » Fri Mar 27, 2015 9:00 pm
Ellis, pop pressure recommendation is always set up for new springs.
Postby CumminsPower59 » Sat Mar 28, 2015 6:53 am
oldestof11 wrote:Ike, whats up with the kid? I am sorry to hear about that.
Her brain is looking to be too big for her skull. Soft spot is aout 2"wide by 3" long. Her head size is almost to the top of the charts, but her body size is in the 10 percentile area. Getting an MRI on the 1st.
DodgeFreak wrote:Wheres the new job at Ike??
Iowa City service center, same company I've been with for two years.
Postby dazedandconfused » Sat Mar 28, 2015 7:36 am
Prayers its nothing serious Ike
Postby AHineman » Sat Mar 28, 2015 8:11 am
X2.
Postby RCCUMMINS89 » Sat Mar 28, 2015 9:39 am
X3... keep us updated.
Postby DMan1198 » Sat Mar 28, 2015 1:33 pm
X4
On another note I pulled the turbine housing apart on my hybrid. The plan is to build a spring gate, open up the wastegate port, drill the divider, and possibly port match it before putting it back in The Roo Hunter as the secondary beside my 467. Hopefully I didn't throw out the hx35 flange that came on my exhaust
Postby DMan1198 » Sat Mar 28, 2015 5:16 pm
So out of curiosity how close to the puck do you guys port the wastegate port to? And how big of hole do you want when drilling the divider?
Postby ellis93 » Sat Mar 28, 2015 6:34 pm
Ike! Same for me brother,I'll send one up as well!
Dman, I drilled mine till I had about 1/16 of flap overlap. Sorry I have no idea what the size of bit was,I couldn't see the size anyhow.
Postby DodgeFreak » Sat Mar 28, 2015 7:39 pm
Need anything Ike, let me know...I'll do what I can!
