2WD To 4WD Conversion..
Re: 2WD To 4WD Conversion..
Postby 1990 » Sun Oct 09, 2011 2:41 pm
I ended up getting the torch out. :lol: Had problems with my electric grinder. I will get some pictures on later.
It's 50" from the front of the front hangers to the centre of the rear hanger. Then 2" above the bottom chord of the frame rail.
I'm doing a crossover steering for it, It's going to work out perfect.
EDIT:
Some pics.
2012 Subaru WRX TP Stage 1 DD
Postby 1990 » Mon Oct 10, 2011 9:14 am
Some more pics.
The truck is resting on it wheels now. I still need to do the steering the brakes.
Postby dazedandconfused » Mon Oct 10, 2011 9:31 am
Are you gonna be able to get it out of the garage with the wheels on it?
Postby 1990 » Mon Oct 10, 2011 9:33 am
dazedandconfused wrote:Are you gonna be able to get it out of the garage with the wheels on it?
Yes. Still have 5" or so.
Postby ahale2772 » Mon Oct 10, 2011 9:52 am
lookin good!!!
Postby BILTIT » Mon Oct 10, 2011 9:57 am
I will have that pitman arm out tonight or first thing in the morning so you should have it by the end of the week at the latest. Progress is lookin good!
Derek B.
BILTIT
Postby 1990 » Mon Oct 10, 2011 2:18 pm
BILTIT wrote:I will have that pitman arm out tonight or first thing in the morning so you should have it by the end of the week at the latest. Progress is lookin good!
Have you got your steering issues solved?
Postby BILTIT » Mon Oct 10, 2011 2:22 pm
Not yet, still waiting for the new pitman arm and then possibly a different draglink.
Derek B.
BILTIT
Postby 1990 » Tue Oct 18, 2011 3:40 pm
Crossover draglink mocked up. Got to add a little bend to add extra room for the oil pan. The pitman arm is from a WJ from partmike.com modified to fit a draglink end taper.
Shock mounts on.
Picked up a grill on Kijiji last month.
Postby ahale2772 » Fri Oct 21, 2011 5:07 am
lookin good!!!... man I love the look of that grill!
Postby 1990 » Thu Oct 27, 2011 2:24 pm
I got everything together and the truck is drivable now.
I put in a 3 inch rear block still a little low in the rear, it will due for now. I will replace all the spring with alcans next year.
Brakes are a little soft, i shouldn't of sold the proportioning valve off the 1993. :roll: I blocked off one outlets on the 2wd prop valve. I don't know if that's my problem or i have air in my master cylinder.
Pics.
Finished crossover steering.
Postby ahale2772 » Fri Oct 28, 2011 4:22 am
looks awesome, its got a nice stance up front. how does the steering feel going down the road?
ive had good luck bleeding the brakes by running lots of fluid throught them, at least 4-5 full open the bleeder up and let it squirt till the pedal hits the floor type squirts (on each wheel).
Ive always had squishy brakes untill I bleed about a full masters worth through the system, if you just pop the rears expecting for the air to be at the bleeder screw it will fool you, usually i get a good streem of stedy fluid then a bunch of air.
I dont know why... but if i do it that way i get a rock hard pedal
Postby 1990 » Fri Oct 28, 2011 3:07 pm
ahale2772 wrote:looks awesome, its got a nice stance up front. how does the steering feel going down the road?
Thanks.
It steering just like a 2wd dodge. Floating and light to the touch. :lol:
Still have more air to get out.
The pedal slowly drops to the floor when pressing on it also. Now if i pump the brakes it really firms up but still drops slowly. No leaks.
Postby ahale2772 » Tue Nov 01, 2011 5:48 am
yep, could, at worst be a bad master, but most likely just air.
logic would tell you air= spongy but stops
dodge=spongy, sinking, weird
Postby 1990 » Thu Nov 03, 2011 6:13 am
Yeah i think i know the problem with the brakes.
Lost an engine mount and broke the fan shroud. :evil:
I'm buying a set of mounts from poly-bushings in Washington.
