vw gti, went and seen one today :shock:
Postby gobigorgohome » Fri Mar 23, 2012 4:44 pm
was out car shoppin and seena GTI that i thought looked ok, guy said he was jackin it up and it fell off the jack and put a hole in the door about the size of a quater. minor stuff right well i seen it needed new brakes and maybe an aligment and some other minor stuff. well i passed on it then but it kept comin back to my mind so i went back for a test drive and i got it and figured out the VW reverse thing then backed out and went to pull out on the street with the salesman in there iwth me and as soon as i got on the road i couldnt even get up to speed the clutch was slippin so bad!!!! at like 1/8 throttle in any gear it would slip if you even moved the pedal a tiny bit lol so i think he was embarrased and then with all the damage he still wanted 6k for it :? told him id give him 3k but he sadi he paid more then that for it, was a good little car tho kinda wanted it real bad :?
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Re: vw gti, went and seen one today :shock:
Postby oldestof11 » Fri Mar 23, 2012 5:22 pm
What year?
Postby gobigorgohome » Fri Mar 23, 2012 6:04 pm
2000 or an 01 cant member
gobigorgohome
Postby oldestof11 » Fri Mar 23, 2012 6:37 pm
6 cylinder or 1.8L turbo? If the turbo'd, I would stay away from the 1st couple model years as they have bad sludge problems.
Postby gobigorgohome » Tue Mar 27, 2012 10:29 am
im not gettin it anyway but it was the 1.8 i think they call it a 2.0. does anyone know what they get for mileage in the real world?
gobigorgohome
Postby oldestof11 » Tue Mar 27, 2012 2:23 pm
At 1 time, you got the VR6 GTI or 1.8 turbo'd GTI. The turbo'd ones get high 20's, low 30s. The 2.slow was a base model engine. The 12v VE Cummins of the VW world. They got swapped into a lot of older VW's. Now the VR6 is the P-pump Cummins of the VW world. Made big power and got swapped into a lot more older cars.
Postby gobigorgohome » Wed Mar 28, 2012 11:12 am
awesome. this is all good to know, a few of my friends said they had problems at 100k like head gskt and sensors goin out. know anything on that?
gobigorgohome
Postby oldestof11 » Wed Mar 28, 2012 2:12 pm
Mainly sludge if the vehicles maintenance and improper oil selection is changed. 5K miles and must be synthetic meeting VW's spec.
The N75 valve is a problematic and like the powerstrokes CPS. Also, any vacuum leaks makes them run like crap. I know these as I helped a buddy fix his Beetle.
Postby gobigorgohome » Fri Mar 30, 2012 8:46 pm
what kinda mileage does the auto 2.slow get in the jettas? things to look for in buying?
gobigorgohome
