kubota
Re: kubota
Postby txs » Fri Jul 13, 2012 7:03 am
It has a rattle and the fan is wobbly, i'm thinking the alternator is under there. This thing sat for about 3 years, wondering if the blowby is stuck rings or wear, meter only shows 880 hours, haven't run it long enough to see if meter works. I need to pull the head and look at the cylinders, might be just needs a set of rings, what would be good for a head gasket, stick with kubota or would felpro or detroit be ok?
txs
Re: kubota
Postby oldestof11 » Fri Jul 13, 2012 2:05 pm
You should know if the hour meter is working if you turn the key to ON. My FIL's works when it is on.
As far as HG, that is up to you.
Re: kubota
Postby ellis93 » Fri Jul 13, 2012 5:17 pm
Jon,that tractor probably has an hr meter in the cable driven tach.
Re: kubota
Postby oldestof11 » Fri Jul 13, 2012 5:37 pm
Whether it is the new or old type, they look electrical...
http://www.kubotabooks.com/AutoIndex/in ... _60164.pdf
http://www.kubotabooks.com/AutoIndex/in ... LDTYPE.pdf
These are downloadable PDF parts manuals. For other manuals:
Hope this helps!
Re: kubota
Postby ellis93 » Fri Jul 13, 2012 6:11 pm
Weird! :?
