new boom stick
new boom stick
Postby ellis93 » Fri Jun 29, 2012 5:38 am
Picked it up REAL CHEAP! :D
its a mossberg made westernfeild 30-30 M72.
Re: new boom stick
Postby tampabayBill » Fri Jun 29, 2012 1:35 pm
Nice score ! I picked a Marlin 30-30 a few years ago for $150 put some cold blue on it and refinished the stock it turned out to be a great shooter. Its cool when you can get a great deal on a good gun.
Twins coming soon!
tampabayBill
Re: new boom stick
Postby lazyjoe » Sat Jun 30, 2012 12:30 pm
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
