Pacbrake.... whats it worth.
Postby 2muchtq » Sat Oct 06, 2007 3:35 pm
I have a Pacbrake off my 93. It fits the h1c and hx35 that uses the v-clamp to attach their downpipe. Mounts directly to the turbo.
It wasn't working when I took it off my truck. I'm not sure how much vacuum it takes to make the valve close... but I dont have enough suck to close the thing (ok ok let the jokes begin)
Anyhow. I have all the pieces.... brake itself, vacuum solenoid, arming switch.
Whats it worth?
Thanks
Mark
2muchtq
Postby 2muchtq » Sat Oct 06, 2007 6:01 pm
Further investigation.
Throttle switch went T/U... and I assume due to lack of use. The shaft that holds the blade has carboned up and is in need of a good cleaning to free it up.
Other than that. This is ready to run.
2muchtq
