A couple of sentences will pretty much override the negatives, I suppose.
It appears to be well built and has a LOT of thought into it.
Given that it IS a CrewCab with a sleeper behind it and that these old school haulers ARE being eliminated, it's definitely unique and appears well-suited for it's original purpose, to haul race cars to the track, because, let's face it, that's just what people BUILT in the 1970s and 1980s.
Racing was the purpose and one of these things, while hell to manuever, solved a lot of issues, like hauling a car and the assorted parts, tools and even a place to sleep (and have carnal relations
Now, if you really wanted to save it and re-power it (you know gas would KILL for it!), a hopped up 4bt can push 250-300 ponies reliably and that would go a long way towards negating the front weight issue, 3.54s and a 6 speed would definitely help the situation (it likely has anywhere from 4.10s to 5.88s!) for the 4 cylinder.
An added bonus, at the expense of another 100 pounds, would be ON BOARD AIR, to blow up tires, run air tools, etc.
With the 4bt, there could be more room for that, while not killing the suspension.
Oh, yeah, I have actually pondered doing this to the hauler I have now, because as impractical as the ol' wedgebed seems to be, the damned thing is just so F-ing COOL!
You wouldn't believe how many times I've considered scrapping it.
And, lastly, I already called on it.
It's a consignment deal, bottom $$$$ is $3700.
