So my truck sort of caught fire...
Postby absentheart » Wed Nov 07, 2012 10:41 pm
My transmission start spewing that expensive NV4500 oil everywhere, I wiped it down so I could see where the leak was coming from and took it for a test drive. I had the shifter off so I could see down to the transmission and was so distracted by fighting the shift stub that I didn't notice that I had the parking break on a couple clicks. So when I pulled back in my drive way all the oil that had gathered inside the brake rotor lit up. I was able to put it out before it did any real damage, first time I was able to put my submarine damage control experience to use on a real fire.
Now smile because you are probably having a better day than me
absentheart
Re: So my truck sort of caught fire...
Postby bmoeller » Wed Nov 07, 2012 11:26 pm
That sucks. Glad you got 'er put out. :D
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby tampabayBill » Thu Nov 08, 2012 7:04 am
Glad you were able to put it out ! We never know when that ole Navy training will come in handy. Hope it didn't hurt the truck much.
Twins coming soon!
tampabayBill
Postby Tacoclaw » Thu Nov 08, 2012 7:24 am
Man, I need to fix that vacuum line to control my HVAC before I end up that desperate for heat. :lol:
Glad to hear you got it put out. :grin:
Postby Hansen01 » Thu Nov 08, 2012 3:20 pm
The previous owner to my truck had put a metal twisty tie around my fuse box, and when i took it off one day it caught on fire in the cab... I know the feeling :lol:
Under construction...
Hansen01
