Bought a replacement truck
Postby meby » Thu Nov 15, 2012 6:49 pm
I picked up an 84' w-250 4 spd tonight. Yeh, I know, its not a diesel. Most of my truck money got spent on a rented bull that went bat-sh*t crazy and went trotting around the county (I had to buy him). Long story. Anyway, i'll have to wait for a diesel until I can save up some more money. In the meantime I needed a truck for the farm. Its got the usual rust, but otherwise is in decent shape. I think I did okay at a $1000.00. I'll try and post a couple pics tomorrow.
The truck runs, but dogs pretty decent when I stomp on the petal. Is that a carb issue or would a good tune-up help?
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Bought a replacement truck
Postby ellis93 » Fri Nov 16, 2012 4:40 am
What kinda carb? If its a thermo quad,throw it away cause it could be your problem and is 100% garbage.
Postby meby » Fri Nov 16, 2012 6:26 am
ellis93 wrote:What kinda carb? If its a thermo quad,throw it away cause it could be your problem and is 100% garbage.
2 barrel. Otherwise I don't know yet.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby ellis93 » Fri Nov 16, 2012 6:46 am
Cool then you got a decent carb,I'd run some seafoam thru the gas before anything else. 1000$ trucks tend to have set for awhile before their found to be useless enough to be sold.
Postby meby » Fri Nov 16, 2012 4:55 pm
ellis93 wrote:Cool then you got a decent carb,I'd run some seafoam thru the gas before anything else. 1000$ trucks tend to have set for awhile before their found to be useless enough to be sold.
That funny. :D
I put in a can of seafoam and ran it some today. I also picked up a steering gear box, power steering pump and starter. The ps wasn't working in the truck. I thought I could run it that way for a bit, but holy cow, its impossible to turn with ps. I Promptly tore it apart when I got home and and broke the power steering lines and discovered the rag joint is squashy and that funny joint by the steering box is in terrible shape (not surprisingly). I might just wind up with a borgsen shaft before i'm done. 8)
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby dazedandconfused » Fri Nov 16, 2012 5:14 pm
Where are the pics?
Postby RumbleFish » Fri Nov 16, 2012 5:41 pm
dazedandconfused wrote:Where are the pics?
Postby meby » Fri Nov 16, 2012 7:42 pm
They're coming. Patience man, patience. Uploading to photobucket as we speak, so to speak.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby Tacoclaw » Fri Nov 16, 2012 7:45 pm
Postby meby » Fri Nov 16, 2012 7:49 pm
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Fri Nov 16, 2012 7:51 pm
okay. okay. happy? :D
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby ellis93 » Fri Nov 16, 2012 8:31 pm
Did the munchkin under the bumper come complete with his own step stool? :lol: sorry had to,I've been told that several times cause I'm usually carrying a metal milk crate with me while walking toward a truck :oops:
Postby bmoeller » Fri Nov 16, 2012 9:24 pm
Looking forward to getting a crew cab bought. :D Planning on running it with the gasser/4spd for a while, then doing the Cummins/5spd/4wd conversion. :D
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Tacoclaw » Fri Nov 16, 2012 9:38 pm
Lose the running boards and I'd call that a truck. :)
Isn't it typically an accelerator pump problem if it lays down when the throttle is goosed? Does it get any better with the air filter pulled off?
I have no real idea on anything gasser anymore, but pulling the filter might tell you if it's leaning out or going rich when it lays down. :?
Postby bmoeller » Fri Nov 16, 2012 9:43 pm
Could be the fuel pump too.
bmoeller
Users browsing this forum: No registered users and 57 guests
