Ain't that just the CUTEST thing!
Postby Mark Nixon » Thu Dec 13, 2012 4:08 pm
Ain't it? :lol:
Re: Ain't that just the CUTEST thing!
Postby dazedandconfused » Thu Dec 13, 2012 4:11 pm
What is that a little 2 cylinder kubota?
Postby oldestof11 » Thu Dec 13, 2012 4:18 pm
Cute little rattly thing...
Postby Mark Nixon » Thu Dec 13, 2012 4:20 pm
Yes, Andy, a 14HP one on a decommissioned APU.
Once I bled the fuel system, it lit right up and the generator works.
Jon, not as rattly as you might think and really quiet for engine and exhaust noise.
Postby oldestof11 » Thu Dec 13, 2012 4:42 pm
Huh. Big (for its size) flywheel? Kinda looks like it.
Postby Mark Nixon » Thu Dec 13, 2012 4:51 pm
It's actually a flywheel with a pulley bolted to it.
It looks bigger (heavier) than it actually is.
Postby PToombs » Thu Dec 13, 2012 5:16 pm
OOHOOHOOH,MEMEME! :bounce:
Sorry Mark, I got a little excited. I've been looking for something like that for the garden tractor, or a 3 cylinder one. I've seen none at all in my area, and I know they're out there. Where did you get it?
Postby Mark Nixon » Thu Dec 13, 2012 5:36 pm
I bought them from a trucking company that upgraded the fleet.
They are from on-board APUs.
The APU housings and the condenser coils were trashed from rust and corrosion, so they are pretty much worthless for their intended use, but I think I can get 1 or 2 usable systems out of the bunch.
Beyond that, these little engines would be ideal for such things as Pete mentioned, or use them for generators. since they'll push 4,000 Watts.
I played with this one and it will idle down. ;)
They are set at max throttle as-is.
I think I can re-position the throttle lever to gain some more RPMs, since max RPMs is around 2,000, wide open. :D
Postby PToombs » Thu Dec 13, 2012 5:46 pm
I know a guy that has something like that on his truck. It's a Rigmaster, 2 cyl (crap, I forgot!) I think it's an Allis Chalmers, diesel that runs a generator and an AC compressor to keep the cab cool and supply power. The AC keeps screwing up and the unit has constant problems. He was talking about getting rid of it. The last I heard, the AC crapped out again and he installed a small AC unit in the cab to use. He removed the passenger seat and has a small fridge there, nice setup.
Postby Mark Nixon » Thu Dec 13, 2012 6:22 pm
Yeah, this is fairly new technology that appears to have a durability problem.
From what I'm reading about this particular model, there's seldom ever a problem with the Kubota engine.
It's the generator, A/C compressor and the control unit in the cab that gives fits.
I wonder what unsafe vehicle I could create to try to use one of these in? :lol:
Something motorcycle based?
Maybe something stick shifted with a giant centrifugal clutch. :D
Postby PToombs » Thu Dec 13, 2012 6:33 pm
I'm sure you can come up with something totally rediculous! :mrgreen: What's one of those critters weigh for shipping? Wanna get rid of one? ;)
Postby oldestof11 » Thu Dec 13, 2012 6:49 pm
Pete, what about one of those 3 cyl Kawi in the JD garden tractors?
Postby PToombs » Fri Dec 14, 2012 6:02 pm
Jon, you know if it says JD then the price is 3 times if it didn't. I see junk ones on an auction site here and they go for stupid money as a parts machine.
Postby bmoeller » Sat Dec 15, 2012 1:13 am
Hmmmm. One of those 2 bangers would be pretty nice in my Deere 216 garden tractor. :D
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Diesel » Sat Dec 15, 2012 7:20 pm
I had that engine in a mini skid steer. They won't start like a cummins so plan on using glow plugs to start but they work. I rarely hit the grids on my truck but with the kubota you have to use glow plugs or its not starting!
1991.5 D250 Intercooled A518
Diesel
