Thoroughbred Facebook Contest
Postby ThatOld1stGen92 » Wed Feb 20, 2013 4:52 pm
So there's a Facebook contest for Thoroughbred Diesel and Flo~Pro exhaust systems, I have entered my truck in the contest and am seeking a little help from you "younger" guys like myself that have a Facebook. If you would go to thoroughbreds page and view posts by others and scroll down until you see my truck (the same truck in my avatar pic) and give it a like it would be greatly appreciated! Thank you so much for your time! And hopefully Dodge will prevail once again! ;)
Andrew "Goose"
'92 Dodge W250 M&H stage 3 fuel pin, 4k governor spring
ThatOld1stGen92
Re: Thoroughbred Facebook Contest
Postby BC847 » Wed Feb 20, 2013 7:15 pm
I can't find you in the Recent posts by others. ?
Postby ThatOld1stGen92 » Wed Feb 20, 2013 7:38 pm
You'll have to scroll for a bit I posted it yesterday at about 3:30! If it helps my name is Andrew Geise on there!
Andrew "Goose"
ThatOld1stGen92
Postby ThatOld1stGen92 » Wed Feb 20, 2013 7:56 pm
BC847 wrote:I can't find you in the Recent posts by others. ?
http://m.facebook.com/home.php?refsrc=h ... 0333518104
Hopefully this works for you sir!
Andrew "Goose"
ThatOld1stGen92
Postby BC847 » Thu Feb 21, 2013 4:49 pm
OK, I've again searched the Thorobred FB page (recent posts by others) and scrolled down to 3:30ish PM on Tuesday, . . . . and I can't find you.
I'm working from a desktop PC. Mobile apps links don't work to well for me. Clicking on the link you've provided gives me this:
The page you requested cannot be displayed right now. It may be temporarily unavailable, the link you clicked on may be broken or expired, or you may not have permission to view this page.
Postby dazedandconfused » Thu Feb 21, 2013 5:03 pm
I get the same thing from mobile.
Postby ThatOld1stGen92 » Thu Feb 21, 2013 5:28 pm
Hmmm I'll try to figure out a good link and then update you all!
Andrew "Goose"
ThatOld1stGen92
Postby ThatOld1stGen92 » Thu Feb 21, 2013 5:35 pm
BC847 wrote:OK, I've again searched the Thorobred FB page (recent posts by others) and scrolled down to 3:30ish PM on Tuesday, . . . . and I can't find you.
Ok since the Facebook link thing is being goofy, the best thing I can do is tell you all that I've got a more recent picture I posted on flo~pros page yesterday at 4:15 on the dot! Hopefully this works for you all, again every vote is appreciated!
Andrew "Goose"
ThatOld1stGen92
Postby Black93 » Fri Feb 22, 2013 10:35 am
I posted mine on there the other day. I went back this morning to look for you and I can't find you either.
Black93
