first time pulling a load
Postby Dodgecrawler2011 » Thu Apr 18, 2013 10:53 pm
Fixn pull my one ton ramcharger here in a few weeks. Alll in all ill be pulling 7k to 8k. Mostly hiway. Trucks a 5 speed sw. Basically stock pump it tweaked a tad bit. This is my first time pulling with this truck and first time witb a diesel.what should I expect. Any pointers
Dodgecrawler2011
Re: first time pulling a load
Postby skilletky » Thu Apr 18, 2013 11:02 pm
Watch your gauges, if you don't have them, get them. Don't lug the Trans. Add an extra quart of fluid to the Trans. Leave yourself pleanty of stopping distance. Make sure you truck brakes and trailer brakes are in proper working order. And watch out for idiots. Oh yeah, check all your fluids before you leave and you should be good to go without much problems or worries.
skilletky
Postby ellis93 » Fri Apr 19, 2013 6:32 am
skilletky wrote:And watch out for idiots.
The MOST important piece of advice you can get. Unfortunately those don't wear signs :lol:
Wouldn't it be nice to walk up on one and see a label stuck on their forehead :mrgreen:
Postby skilletky » Fri Apr 19, 2013 6:54 am
ha ha, that would be awesome. or a big light up sing on their car that says " hey, im dumber that sith and im gonna pull out in front of your loaded down truck going 55, so you better watch out"
skilletky
Postby Dodgecrawler2011 » Fri Apr 19, 2013 8:10 am
Yes ive pulled 100s of times but always with a gas motor. Just not use to "how" to use the diesel power
Dodgecrawler2011
Postby ellis93 » Fri Apr 19, 2013 8:17 am
Dodgecrawler2011 wrote:Yes ive pulled 100s of times but always with a gas motor. Just not use to "how" to use the diesel power
Same thing....keep your RPMs up and it'll do fine. I never shift till 2200 or above,lugging will eventually eat something
Postby Dodgecrawler2011 » Fri Apr 19, 2013 9:00 am
Is that 8k even going to strain it
Dodgecrawler2011
Postby dazedandconfused » Fri Apr 19, 2013 9:09 am
Not as bad as a gas try k but behind a mostly stock Cummins you will notice it a bit.
Postby RumbleFish » Fri Apr 19, 2013 9:13 am
Dodgecrawler2011 wrote:Fixn pull my one ton ramcharger.
Umm, yeah...we're gonna need some pics of this...
Postby Mark Nixon » Fri Apr 19, 2013 9:52 am
If you have heavy rear springs in it from the Diesel donor, take my advice, soften the crap out of them and run airbags on the rear.
First washboard road you hit, you'll either hit the ditch or crap your pants.
I did neither, but I never towed with it again, either.
Oh, and if you have man boobs and stiff suspension, your chest is gonna' hurt with that short wheel base, even on mildly rough roads. :lol:
Postby skilletky » Fri Apr 19, 2013 9:58 am
Mark Nixon wrote:Oh, and if you have man boobs and stiff suspension, your chest is gonna' hurt with that short wheel base, even on mildly rough roads. :lol:
:jumpsmile:
skilletky
Postby ellis93 » Fri Apr 19, 2013 10:25 am
:jumpsmile:
Postby Dodgecrawler2011 » Fri Apr 19, 2013 11:36 am
No no lol. My truck is a 92 sc long bed. My toy is a one ton ramcharger.
Dodgecrawler2011
Postby Mark Nixon » Fri Apr 19, 2013 12:13 pm
Hmm, the way the OP reads, IS kinda' vague. :?
Glad you AREN'T towing with the RC, at any rate. 8)
