01 24v cab and chassis whats it worth
Postby DodgeFreak » Fri Aug 08, 2014 4:18 pm
This 01 24v 6spd 2wd 3500 that's kicking my butt the kid's about ready to just unload it as is (hard to start but runs smooth) Cabs rotted on the ds and same with the fender passenger side isn't terrible.
The thing leaks oil like crazy out of the front seal, rear pinion seal leaking, tires are just street tread and not the greatest, the whole front end has been gone through probably 6-8k miles ago, just put a reman ps pump on it. Whats it worth? He's thinking 3k I'm thinking I could talk him down to around 2k.
Re: 01 24v cab and chassis whats it worth
Postby dazedandconfused » Fri Aug 08, 2014 5:22 pm
That's about right.
Postby DodgeFreak » Fri Aug 08, 2014 5:23 pm
2k or 3k?
Postby dazedandconfused » Fri Aug 08, 2014 5:25 pm
I would say around 2 since I'm betting it needs a IP.
Postby DodgeFreak » Fri Aug 08, 2014 5:27 pm
He has one, I'm just waiting to see if he wants to go a head and have me install it...So, I'm not sure if I can swing it, but I'm going to try and convince my wife to let me lol.
Postby ellis93 » Fri Aug 08, 2014 5:44 pm
I'd go 2 on it for the 6spd. Then I'd gut that thing,ve the 24v and drop it and the 6speed in my dodge 8)
Postby RCCUMMINS89 » Fri Aug 08, 2014 8:46 pm
ve 24 valves seem to run pretty good. Not that they make much more power, but seem to be more efficient all the way around.
Postby cougar » Sat Aug 09, 2014 10:29 am
P pump it instead.
01 2500 "the work truck".
cougar
Postby RCCUMMINS89 » Sat Aug 09, 2014 5:58 pm
Why?
