Whats every one do for work?
Postby GPSMatt » Wed Dec 05, 2007 5:25 pm
I drive Tow trucks..
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby GO OVRIT » Wed Dec 05, 2007 5:54 pm
I work on stuff.....
GO OVRIT
Postby rbrettctd » Wed Dec 05, 2007 6:27 pm
Im a rancher when Im not going to school for ranching.
Randy
rbrettctd
Postby CumminsPride » Wed Dec 05, 2007 6:43 pm
I'm a telephone repairman/journeyman electrician!
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby RumbleFish » Wed Dec 05, 2007 7:26 pm
I work in a factory building overpriced rich people boats. I also got a part time gig at O'Reilly auto parts to earn a hefty discount
Postby 2muchtq » Wed Dec 05, 2007 7:31 pm
Construction Junky.
Presently building/updating a sewer treatment plant.
Trying to get into an electrician apprenticeship.
2muchtq
Postby TWorline » Wed Dec 05, 2007 7:40 pm
I work for a local Agricultural Co. driving semi, spraying crops, spreading fertilizer, being a mechanic and doing fab work.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby flashgordon » Wed Dec 05, 2007 9:32 pm
I twist wrenches on the new dodge diesel :hs: ................and now you now why i own a "Old Dodge". :lol:
Flash.
flashgordon
Postby ytodd » Thu Dec 06, 2007 11:38 am
IT
ytodd
Postby CAJUN 93 » Thu Dec 06, 2007 12:02 pm
Mopar parts guy. wife works for oreilly's. got my parts situation covered :lol:
daryl
CAJUN 93
Postby PToombs » Thu Dec 06, 2007 4:49 pm
Case heavy equipment mechanic. Got the Cummins parts covered! ;)
Postby cummins king » Thu Dec 06, 2007 5:39 pm
drive trucks drive heavy equipment, fix stuff, run a garden center, and the list keeps going on
93 4X4 auto
cummins king
Postby Philip » Thu Dec 06, 2007 10:40 pm
Plant maintanence in a alumn smelting company.
Postby Underpsi » Fri Dec 07, 2007 6:59 pm
I drive Multi axle flat bed and help out in the shop when we are slow
1989 D250 5spd w/SB3250DD, .020 over head gasket, O-rings, Extensive port/polish, ARP head studs, 62/71/14, 6x.018 sticks. First Dyno stock turbo and pods: 343/879
2nd with 62 & big sticks: 393/813
Underpsi
Postby wannadiesel » Sat Dec 08, 2007 7:11 am
Bottle kicker. I drive a cylinder truck for Scully Welding Supply, it's an '01 Sterling tandem axle underpowered by a Cat 3126. :roll:
Best dyno: 408/844
wannadiesel
diesel guru
