Hello 1st gen guys!
Hello 1st gen guys!
Postby conxds » Sun Dec 27, 2015 6:00 pm
Hello, im new to the forum names Connor some of you might know the username conxds from cumminsfoum.
Figured id join up over here since there seems to be a wealth of knowledge on these older trucks!
currently I have a 93 4x4 extended 5 speed that im fixing up, a 1992 sinlge cab 4x4 all original with under 100K a 95 2wd tow pig and a 98 24v pushing around 600hp.
Glad to be a part of the group and thought id do a brief intro, thanks in advance for the help on any future questions!
conxds
Re: Hello 1st gen guys!
Postby 1STGENFARMBOY » Sun Dec 27, 2015 8:55 pm
hey
Postby RCCUMMINS89 » Wed Jan 06, 2016 12:13 am
HEY
Postby 1STGENFARMBOY » Thu Jan 07, 2016 7:58 pm
HEY........it's faaaaaat albert..................... oh never mind.
600hp eh..... so that's like stacked chips or something.........or .......live CSI tuning. :mrgreen:
Postby 2uphill » Wed Mar 02, 2016 9:10 pm
Hmmmm....:) :) :) ...
90 d350, SRW, 2wd, 727, stock, except banks i/c, 85K
84 w350 crew cab, I/c 89, s300, 727, 4x4, 130K
90 w350cc, 3.54, getrag, 125K
82 d350 crew cab project
2uphill
Postby 2uphill » Wed Mar 02, 2016 9:17 pm
welcome...I'm learning too,..where did you pick up your extended 5 speed... I been looking for one
2uphill
Postby spencerdiesel » Sun Mar 06, 2016 7:17 pm
Hola
H1C/18
Muffler delete
spencerdiesel
Postby CumminsPower59 » Mon Mar 07, 2016 2:25 pm
Welcome!
Postby FrankenRam » Fri Sep 23, 2016 10:42 am
Rocky Mountain parts pro.
I'm currently building a 85 D150 canyon burner and replacing the slant 6 and torqueflite with a 318 from a 95 ZJ and a NV3500 5 speed, pedal cluster, master cylinder and booster from a 99 Ram 2500 2WD. should be pretty quick with solid towing power. couple more weeks and it should be back on the road.
FrankenRam
Postby Philip » Sat Sep 24, 2016 5:30 pm
318 with solid towing power. Sorry towing power and 318 do not go into the same sentence. That is some major conflict of terms there. :lol: :lol:
Remember this is a diesel site. We know about towing power. :mrgreen:
Welcome to the forum.
Postby DodgeFreak » Mon Sep 26, 2016 2:01 pm
Come on Philip, 318's made good power. That's all I pulled with before I bought a diesel. my 92 318 Dakota pulled my cummins D250 reg cab long bed. Pulled it great, couldn't stop. lol.
Postby Philip » Tue Sep 27, 2016 8:30 pm
DodgeFreak wrote:Come on Philip, 318's made good power. That's all I pulled with before I bought a diesel. my 92 318 Dakota pulled my cummins D250 reg cab long bed. Pulled it great, couldn't stop. lol.
In the Dodge line up. I have towed with 318/340/360/400's. I'll take a big block hands down. Same for Chevy's. I have towed with all engines they made from 60 onward. Another big block call there.
Fords I don't go there. I wouldn't tow with anything diesel they have. If I was held at gun point to tow with a ford. I would want a good condition FE engine. 390 or mid rise 427/428. 460's were low compression after 71. A good 390 could out pull them on hills.
Postby DodgeFreak » Wed Sep 28, 2016 1:18 pm
I've towed with a 318\360\3.9 v6 and 440. I can't afford the gas in a 440. I don't think I've ever driven a Ford that could pull anything.
Postby Philip » Thu Sep 29, 2016 8:33 pm
If you want to talk Dodge gasser towing. The first thing I always did to any Dodge engine. Remove the stock intake and carb. Throw into closest scrap pile. Install after market intake and carb. I used Holleys myself. Then dial the carb in to the engine. Don't leave the Holley box stock. They need setup to the engine for jetting and power valve opening rate. Stock Holleys opened the power valves to soon for most stock engines. If you had deep rear end gearing like trucks used. It killed fuel milage.
Postby Richie O » Fri Sep 30, 2016 6:18 pm
What about the leaning tower of power????? :D My dad had a 1968 1 ton dump he hauled wood on. His trips were 3.5 cords of green oak to the paper mills. Been up plenty of hills in granny low just barely turning over. That was back when you could get away with that.
